The Very First S-Caliper?, an interesting look at one of DaveP's calipers |
Eric_Shea |
Jun 14 2008, 12:23 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Dave Pateman sent some S-Calipers down for a dichromate re-do (not these in the thread, a later pair off a 73+ car) and he graciously sent an odd-ball caliper he had laying around for me to have a look at.
It sure proved interesting and, I have my "theory(s)" as to what it is and how it, and the following S-Caliper lineage came to be. The theory goes like this: Porsche has been well documented in proving a concept at the track and then positioning that concept on their production line vehicles. I believe that ATE was commissioned to make a lighter caliper for their racing vehicles. I believe what we're about to see is one of the first basic S-Calipers to exist. On with a tale of two S-Calipers: Mine's on the left. It's a reconditioned, very early (69-70) S-Caliper that I will be using on my GT car. Dave's one-off is on the right. The first glaringly obvious difference is the endurance pad pin assembly. Any car that is going to go through S-Caliper pads in a single race is probably going at it for 24 hours. Upon further inspection, this caliper was finish machined slightly different as well. The tops were flattened but only by a small amount. Various logos and markings are not in the usual production locations and there's a few "niceties" that would be missing. I'll try to cover it all herein. First let's look at the bottom side logos. Both are "basically" in the same place but, the casting lines from the production caliper (red arrow) is missing and the logo is centered (refinishers buffed the other logo a tad much): The flute around the pad cavity is slightly different. These calipers are nearly identical with the exception of some of these things which lead me to believe a later production model was molded off the same casting. The later flute is slightly deeper: Again, markings and castings are slightly different. I do not believe the 68 represents a year. Mine have similar markings elsewhere on the caliper and they're something like 33. I would guess a finisher stamp?? Here's one of the convenience things or "niceties" I found. It's a pain in the @$$ to get S-Caliper lines and bleeders off. These must have been a bear. Note how the later production model caliper differs: This stamping on the machined top tells me this was no afterthought to make it fit a certain wheel. The race dept. probably worked closely with ATE for these specs.: Here's the two side by side. Again, proportionately these calipers are identical. You can see how they finished the top on this caliper: On the side of the nose of the caliper there's an odd bump, possibly denoting the back of the piston chamber. The production model bump is more pronounced: Here's a little more detail on the quick-change endurance pad pin. While this was a rather crude adaptation to the original caliper, I do believe it falls right in line with a factory race look and feel. I'm fairly certain this was an original mod.: Pistons are different. The one-off has a very deep piston top. The standard S-Caliper piston is pictured in-hand: The pin assembly itself is rather crude and not even but again I think this is a factory manifestation. I've seen these pins on one other set of calipers but without the latch mechanism. All in all, it was an interesting afternoon (for me anyway). Here's a full-on shot of both calipers (pay no attention to the two pair of original GT calipers in the background!): What are your thoughts? |
Jeff Hail |
Jun 14 2008, 03:19 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
What are your thoughts? I know exactly what they came from and what the markings mean. Those are calipers that were used on the 908 race car. On rare instances they could be found on the factory late 904, 914-6GT and 911ST race cars as an upgrade to the stock brakes. The quick change Uni-pin is the give away that they are race parts normally found on endurance racers where fast pit time were just as important as a fast lap. Other hints that they came from somewhere betwen 904-908 series is the machined "head" allowing more clearance for a smaller wheel. Some 904-908 hill climb cars used diminutive 13 inch wheels as the front bodywork was lowered to provide improved areodynamics and reduced frontal area. The caliper head would have to be machined to allow clearance for a smaller wheel. The "V" stamping indicates a very early caliper possibly as early as the 904 model. The "V" stamp was a designation for Ollon-Villar cars which were used in hill climbs and carried over into the 908, 911ST and 914-6GT models as an option. The numerical stamp was a batch value not a year of production. Adding a twist those are 910-907 pistons. Porsche learned the leading edge of the pads would wear faster than the trailing edge in racing. A redesign of the piston was made from earlier models and this would carry all the way over to into the 917 caliper pistons from lessons learned. The deep piston also helped with heat keeping the heat from transfering from the pad to the caliper body preventing fluid boil. The pistons were machined with an ever so slight cant to allow for even wear front to rear along with a deeper cut in the dish area. I bet if you mic the pistons you will see a 2 thousands difference where the front and rear of the pads meet the face. Here is a sample of the 908 Quick Change calipers with shaved heads and the later 910-07s with updated pistons. The physical differences are clear in the photos. Eric you have a great eye for noticing the differences that you found. That sample is worth its weight in gold. Proving again you are the Master. Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 07:24 AM |
