| Ian Stott |
May 11 2008, 12:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
My Fuchs just got dropped off and I bought the Mothers Power Ball and Mothers Power Metal ( Aluminium ) Polish. Going to power wash the rims first then I thought I would check with club members before I did anything else just in case there is a chance I could do more harm than good. I read in a previous post somewhere that a fine grit sandpaper had been used, I am scared shitless to do that for some reason. All comments appreciated even the smart ass ones!
Ian Stott Moncton Canada Candidate for slowest restoration ever! |
| agent9 |
May 11 2008, 05:00 PM
Newbie ![]() Group: Members Posts: 36 Joined: 9-May 08 From: San Francisco, CA Member No.: 9,037 Region Association: None |
ya, im in the same boat. PO painted em, they look ok, but i think they would look amazing with the paint removed and polished. so any more advice on how to get from here to there would be appreciated.
i am assuming this can be done while still on the car, or at least with the tire still attached? here is a shot of what im dealing with: (IMG:http://www.mashinenoise.com/914pics/wheel.jpg) also anyone know what kind of rim this is? is it factory or aftermarket? i was told it was one of the lightest 4 lugs made, but who knows. |
| beech4rd |
May 11 2008, 07:39 PM
Member ![]() ![]() Group: Members Posts: 348 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States
ya, im in the same boat. PO painted em, they look ok, but i think they would look amazing with the paint removed and polished. so any more advice on how to get from here to there would be appreciated. i am assuming this can be done while still on the car, or at least with the tire still attached? here is a shot of what im dealing with: (IMG:http://www.mashinenoise.com/914pics/wheel.jpg) also anyone know what kind of rim this is? is it factory or aftermarket? i was told it was one of the lightest 4 lugs made, but who knows. These are Pedrini wheels, original equipment on some 914s before 1973. They were made in Italy and are sand cast, unlike Fuchs, which were die cast. As a result of the casting process, the surface of these wheels, when stripped of paint, is far from being smooth, in fact, under magnification, the surface is a mass of pits, a result of the sandcasting process. One of the reasons the wheels are as light as they are is a result of air trapped in the metal during the casting process. You can polish these wheels until you are blue in the face and they will never shine as a Fuchs will. So, get some paint stripper, remove the old paint,carefully file and sand any dings off the rim, buy a couple of cans of the Wurth silver wheel paint and you can return the wheel to the appearance it had originally. They will look quite handsome. |
| G e o r g e |
May 12 2008, 01:14 PM
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None
sticking with the pedrini's for a moment
I agree the sand cast is less desirable for polishing I have a set that look great from 5 + feet but would need a lot of holes filled grinded and more polish to be perfect so if you have the time do it ya, im in the same boat. PO painted em, they look ok, but i think they would look amazing with the paint removed and polished. so any more advice on how to get from here to there would be appreciated. i am assuming this can be done while still on the car, or at least with the tire still attached? here is a shot of what im dealing with: (IMG:http://www.mashinenoise.com/914pics/wheel.jpg) also anyone know what kind of rim this is? is it factory or aftermarket? i was told it was one of the lightest 4 lugs made, but who knows. These are Pedrini wheels, original equipment on some 914s before 1973. They were made in Italy and are sand cast, unlike Fuchs, which were die cast. As a result of the casting process, the surface of these wheels, when stripped of paint, is far from being smooth, in fact, under magnification, the surface is a mass of pits, a result of the sandcasting process. One of the reasons the wheels are as light as they are is a result of air trapped in the metal during the casting process. You can polish these wheels until you are blue in the face and they will never shine as a Fuchs will. So, get some paint stripper, remove the old paint,carefully file and sand any dings off the rim, buy a couple of cans of the Wurth silver wheel paint and you can return the wheel to the appearance it had originally. They will look quite handsome. Attached image(s)
| Cevan |
Jun 17 2008, 10:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
sticking with the pedrini's for a moment I agree the sand cast is less desirable for polishing I have a set that look great from 5 + feet but would need a lot of holes filled grinded and more polish to be perfect so if you have the time do it ya, im in the same boat. PO painted em, they look ok, but i think they would look amazing with the paint removed and polished. so any more advice on how to get from here to there would be appreciated. i am assuming this can be done while still on the car, or at least with the tire still attached? here is a shot of what im dealing with: (IMG:http://www.mashinenoise.com/914pics/wheel.jpg) also anyone know what kind of rim this is? is it factory or aftermarket? i was told it was one of the lightest 4 lugs made, but who knows. These are Pedrini wheels, original equipment on some 914s before 1973. They were made in Italy and are sand cast, unlike Fuchs, which were die cast. As a result of the casting process, the surface of these wheels, when stripped of paint, is far from being smooth, in fact, under magnification, the surface is a mass of pits, a result of the sandcasting process. One of the reasons the wheels are as light as they are is a result of air trapped in the metal during the casting process. You can polish these wheels until you are blue in the face and they will never shine as a Fuchs will. So, get some paint stripper, remove the old paint,carefully file and sand any dings off the rim, buy a couple of cans of the Wurth silver wheel paint and you can return the wheel to the appearance it had originally. They will look quite handsome. How did you polish those Pedrini's? I tried to polish the fins on one of my Mahles, which I believe are cast the same way and I couldn't get nearly the shine you have. I used sand paper up to 1500 grit and then aluminum polish. |
Ian Stott Polishing Fuchs May 11 2008, 12:45 PM
PRS914-6 I use Mothers on mine with a micro-fiber towel. T... May 11 2008, 12:55 PM
race914
My Fuchs just got dropped off and I bought the Mo... May 11 2008, 01:11 PM
Ian Stott First your rims look great, did you use anything o... May 11 2008, 02:17 PM
race914
First your rims look great, did you use anything ... May 11 2008, 02:47 PM
Ian Stott Let me know how your "trying/applying the met... May 11 2008, 03:04 PM
r_towle how can one get the anodizing off yet retain the w... May 11 2008, 03:12 PM
rfuerst911sc
how can one get the anodizing off yet retain the ... May 11 2008, 04:00 PM
jsayre914
how can one get the anodizing off yet retain the... May 11 2008, 04:21 PM
rfuerst911sc
[quote name='rfuerst911sc' post='1030813' date='M... May 11 2008, 05:41 PM
jsayre914
[quote name='rfuerst911sc' post='1030813' date='... May 11 2008, 06:00 PM
Phoenix 914-6GT :popcorn: May 11 2008, 03:13 PM
Ian Stott Let me get this straight, the original finish is a... May 11 2008, 04:11 PM
scotty b
Let me get this straight, the original finish is ... May 11 2008, 04:15 PM
Ian Stott The more knowledgeable people/members can tell wha... May 11 2008, 05:25 PM
Ian Stott Tell me more about the different grits of sandpape... May 11 2008, 07:01 PM
degreeoff Its just aluminum. So that in mind sand paper will... May 11 2008, 07:19 PM
PRS914-6 OK, Now that I see what you are dealing with I hav... May 11 2008, 08:32 PM
brant the above steps combined are my process too
1) us... May 11 2008, 08:41 PM
Ian Stott Thanks to all who chimed in, I feel much better in... May 12 2008, 01:47 AM
i love porsche heres a good process haha
http://forums.vwvortex.... Jun 17 2008, 01:30 PM
Challe Isn't Mahles made of magnesium or other ... Jun 17 2008, 01:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:46 PM |
