Brazing: How do you get rid of it?, on the trunk pivot... |
swood |
Jan 2 2004, 04:51 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I'm having a tough time removing the pivots. How do you get rid of the brazing? I found more of it used in the trunk to fill a small rust hole.
I don't want to grind too much in case I cut through the sheet metal, and the grinder wheel (4.5") is too big to get the rear side. Suggestions? Attached image(s) |
swood |
Jan 3 2004, 10:18 AM
Yes it helps, thanks for the enlightening. Just a drag to deal with. I'll have to check with the neighbors and see who has what as far as torches go. I've got MAP in a small plumbers type torch, but I doubt that'll get hot enough. I'll try it though. (IMG:style_emoticons/default/blowtorch.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 06:23 AM |
