914 Tool Kit info, Correct for a 1973-1974 914-4 cyl. kit |
TJB/914 |
Apr 30 2006, 09:53 AM
Mid-Engn. Group: Members Posts: 4,334 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Lets start a list of correct 914 Tool Kit parts.
Here's one for a 1973 & 1974 914-4 cly. car (Comments please to confirm??) Tom Attached thumbnail(s) |
TJB/914 |
Apr 30 2006, 11:11 AM
Tool Kit for a 914-6
Tom Attached image(s) |
smontanaro |
Jun 19 2008, 08:29 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Tool Kit for a 914-6 Tom Dredging up an old thread here. I see in Tom's post he has a blister pack of red fuses. Later on he admits it's not original. Does anyone have a picture of what the original looked like? Also, I see a little something else poking out of the pouch next to the red fuses. Is that another small fuse pack? A couple other questions. My pouch also has the darkening seen on the right side of the image. Is that from the fan belt rubbing or something else? Any idea if it's possible to clean it? Finally, my pulley wrench has a little bit of a twist in it between the pins. Is that typical from use/abuse or did they come that way? (The pulley wrench in the 911 kit I just sold on evilBay had the same sort of twist, so using my small sample size I will lie with statistics and suggest that's a pretty typical "feature".) Thx, Skip Montanaro |
sixerdon |
Jun 19 2008, 09:31 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Tool Kit for a 914-6 Tom Dredging up an old thread here. I see in Tom's post he has a blister pack of red fuses. Later on he admits it's not original. Does anyone have a picture of what the original looked like? Also, I see a little something else poking out of the pouch next to the red fuses. Is that another small fuse pack? A couple other questions. My pouch also has the darkening seen on the right side of the image. Is that from the fan belt rubbing or something else? Any idea if it's possible to clean it? Finally, my pulley wrench has a little bit of a twist in it between the pins. Is that typical from use/abuse or did they come that way? (The pulley wrench in the 911 kit I just sold on evilBay had the same sort of twist, so using my small sample size I will lie with statistics and suggest that's a pretty typical "feature".) Skip, Check out that web site mentioned above. http://www.p914.com The fuse kit pictures are shown. "Pudenz" is marked on the holder. The article claims the fuse kit is not part of the tool kit, but instead is kept in the glove compartment. I found that interesting. My wife used simple green to clean up the pouches. Takes awhile. You might try magic eraser, too. My pulley wrenches are straight. Hope this helps. Don Thx, Skip Montanaro |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:04 AM |
