> Mysterious oil leak
Curvie Roadlover
post Mar 10 2003, 08:12 PM
Two trunks are better than one!
I have an oil leak on my '76 that seems to not follow usual patterns. The leak only occurrs when the car is warming up. It doesn't leak when it's just sitting and it doesn't leak near as bad (almost not at all) once the car warms up. It drips off the oil filter, but I can see the oil dripping from the oil cooler above, onto the filter. At it's worst, it drips about a drop a second. I suspect the oil cooler seals, but, wouldn't that leak all the time, not just at warm-up? And it certainly seems like the drip wouldn't slow down when the car is warmed up if it was the cooler seals. I also kept an eye on the oil pressure sensor and didn't see any oil leaking in that area. (IMG:style_emoticons/default/confused24.gif)
Thanks in advance for your thoughts,
Tom
Mike D.
post Mar 23 2003, 06:23 PM
OK, It runs now, and pretty good too!
pressure sensor and cooler seal leaks appear at the back of the cooler, obviously where the seals are. If oil is dripping from the coolers center, front or far right then the cooler itself is probably leaking.
No leaking when stoped - no pressure.
slower after it warms up could be from heat expansion making a crack in the cooler tighter. Maybe (IMG:style_emoticons/default/confused24.gif)?
Mike D.
- Lo-Fi Version Time is now: 1st July 2025 - 03:12 AM
