orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
heres the skinny, we just got the new 2056 installed at a local shop. it fired right up, good fuel & oil pressure, real responsive. it idles abit rough with an occasional pop thru throttle body at idle. shop owner took it for a ride and said it felt like it was a head gasket leaking. cruised good but under a load it pop,pop,popped. when we built it we checked the registers...flat. we lapped cylinders to head... check. we torqued heads... click. can possible overtorqueing create leak?
it's d-jet with a modified mps to match the engine. i'm abit frustated as it was kinda the red headed step child sitting in the corner. (IMG:style_emoticons/default/dry.gif) i know there will need to have further work to clean up hose routing. i also know the aux. valve is NOT plumbed in yet (only issue i KNOW of). could that cause the above "possible head gasket leak sound/feel" i think everything else is plumbed good. it almost acts like a vacuum leak, or crossed plug wires, they swear there are no intake vacuum ports open and they re-checked the firing order. any thoughts on a stuck injector or maybe an intake valve may be too tight. the occasional pop thru the intake at idle makes me think it could be one of those (IMG:style_emoticons/default/sad.gif) . maybe an intake is too tight (chromoly set at 0 backlash as jake says). the valves were re-set after 20 min. break in running 30 wht. brad penn break in oil then changed to b.p. 20x50 i guess the next step is confirm wire order, get aux. valve hooked in, run a compression test. then take to a shop with a sniffer. after a year build and many challenges my poor son kenny is burnt out. i keep telling him he's almost there. oh yeah it does have a few minor push rod tube leaks, are there different size tubes (at the o-ring?) i know from many post the o-rings getting cut seems very common. mike |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
exhaust leak, valves, timing, all the above ...
i thought head gaskets on a T4 were a thing of the past!?!? (IMG:style_emoticons/default/confused24.gif) Andy |
orange914 |
exhaust leak, valves, timing, all the above ... i thought head gaskets on a T4 were a thing of the past!?!? (IMG:style_emoticons/default/confused24.gif) Andy no head gaskets here... his words, i should have been more clear. but thats also what makes me think he's wrong. i guess a compression check is next. after a weekend of thess (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) i dont think exaust leak because of acompaning engine cut out. it has the oversized new studs from jack, besides i even annuled the copper seals... i really hope it's an injector or maybe aux air not being hooked up yet. (IMG:style_emoticons/default/headbang.gif) mike |
Lo-Fi Version | Time is now: 13th June 2024 - 05:29 AM |
