> when taco plate senders go bad...
type47
post Jun 30 2008, 08:16 AM
Viermeister
i'm troubleshooting my oil temp in the combo gauge that doesn't give a temp reading. when i turn on the ignition, i see the needle jump to the cold line but no deflection on a warmed up engine. i measured the resistance of a spare taco i had on the bench and got about 1300 ohms and the one on the engine in the car doesn't give any resistance so i've deduced it's bad and will swap it next oil change.
do taco plate senders ever go bad?
r_towle
post Jun 30 2008, 08:51 AM
Custom Member
I agree.
There are two connectors that could be dirty enough after 35 years to give false/no readings.
One is under the computer/battery tray. Its where the wire comes up into the engine bay and plugs into the wiring harness. Good place for corrosion.
The second is under the tunnel carpet, passenger side just near the shifter. Again...good place to get wet over the years.
The nice part is these two connectors give you a built in place to test the sender as you mover towards the gauge.
rich
- Lo-Fi Version Time is now: 1st August 2025 - 04:36 AM
