| 1fastredsc |
Jun 15 2008, 01:33 AM
Newbie ![]() Group: Members Posts: 40 Joined: 4-May 08 From: LC, NM Member No.: 9,010 Region Association: None |
Can someone recommend a general blasting media for a blasting cabinet? I might go out and get one either tomorrow or the day after but i'm not sure which type of media to put in it. I want to use it to clean off the various steel and aluminum parts in these cars (probably mostly steel to strip paint and rust and then repaint stuff). I know not to use sand with aluminum parts, and the harbor freight here in town sells different grit walnut shells and glass beads.
| 1fastredsc |
Jun 30 2008, 03:12 PM
Ok, last question i promise. I have a blasting cabinet now, all setup and been using it on some suspension parts. But now i'm getting glass bead dust all over the back of the cabinet right by the vent. It has a port on the side for a vacuum hook up. Does anyone here use the vacuum hook up and if so what type of vacuum is needed? Can i use my craftsman shop wet/dry vacuum on it, or does it require some special type of vacuum?
1fastredsc Blasting cabinet media Jun 15 2008, 01:33 AM
914Sixer Use the glass beads. If you have a Tractor Suppl... Jun 15 2008, 07:33 AM
Brian_Boss Like a lot of things in life, no one product is go... Jun 15 2008, 09:00 AM
Gint Glass bead meets most of the needs in my garage. ... Jun 15 2008, 09:36 AM
euro911 Glass bead works great Jun 15 2008, 09:59 AM
scotty b :agree: Glass bead Got it at werk, got it at home... Jun 15 2008, 10:16 AM
1fastredsc Will course grit glass bead at a higher pressure b... Jun 15 2008, 01:54 PM
736conver I have fine glass bead and coarse bead. I also ha... Jun 15 2008, 02:15 PM
1fastredsc I understand that, but what i was trying to ask is... Jun 15 2008, 05:30 PM
John
I understand that, but what i was trying to ask i... Jun 15 2008, 10:20 PM
Kansas 914
I understand that, but what i was trying to ask ... Jun 16 2008, 07:36 AM
PRS914-6 I actually use a 50/50 blend of glass beads and al... Jun 15 2008, 05:34 PM
1fastredsc That's exactly what i was curious about. Thank... Jun 16 2008, 01:35 AM
914Sixer If I am going to paint item after it has been bead... Jun 16 2008, 06:44 AM
PRS914-6 That's normal without a vac unit. You can use... Jun 30 2008, 05:55 PM
smdubovsky Use a 'drywall' sanding filter. The only ... Jul 1 2008, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 04:23 PM |
