| 1fastredsc |
Jun 15 2008, 01:33 AM
Newbie ![]() Group: Members Posts: 40 Joined: 4-May 08 From: LC, NM Member No.: 9,010 Region Association: None |
Can someone recommend a general blasting media for a blasting cabinet? I might go out and get one either tomorrow or the day after but i'm not sure which type of media to put in it. I want to use it to clean off the various steel and aluminum parts in these cars (probably mostly steel to strip paint and rust and then repaint stuff). I know not to use sand with aluminum parts, and the harbor freight here in town sells different grit walnut shells and glass beads.
| PRS914-6 |
Jun 30 2008, 05:55 PM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
That's normal without a vac unit. You can use the shop vac but you should have a filter mounted in the inside. If not, the glass bead dust will go through the motor and in a short time the motor will sound like it has gravel in it. Been there, done that
1fastredsc Blasting cabinet media Jun 15 2008, 01:33 AM
914Sixer Use the glass beads. If you have a Tractor Suppl... Jun 15 2008, 07:33 AM
Brian_Boss Like a lot of things in life, no one product is go... Jun 15 2008, 09:00 AM
Gint Glass bead meets most of the needs in my garage. ... Jun 15 2008, 09:36 AM
euro911 Glass bead works great Jun 15 2008, 09:59 AM
scotty b :agree: Glass bead Got it at werk, got it at home... Jun 15 2008, 10:16 AM
1fastredsc Will course grit glass bead at a higher pressure b... Jun 15 2008, 01:54 PM
736conver I have fine glass bead and coarse bead. I also ha... Jun 15 2008, 02:15 PM
1fastredsc I understand that, but what i was trying to ask is... Jun 15 2008, 05:30 PM
John
I understand that, but what i was trying to ask i... Jun 15 2008, 10:20 PM
Kansas 914
I understand that, but what i was trying to ask ... Jun 16 2008, 07:36 AM
PRS914-6 I actually use a 50/50 blend of glass beads and al... Jun 15 2008, 05:34 PM
1fastredsc That's exactly what i was curious about. Thank... Jun 16 2008, 01:35 AM
914Sixer If I am going to paint item after it has been bead... Jun 16 2008, 06:44 AM
1fastredsc Ok, last question i promise. I have a blasting cab... Jun 30 2008, 03:12 PM
smdubovsky Use a 'drywall' sanding filter. The only ... Jul 1 2008, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 04:20 PM |
