Left A-arm torsion bar won't insert..., Pound more, use bigger hammer? |
neo914-6 |
Jul 1 2008, 03:22 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Some history, the a-arms were from Mueller assumed to be in good condition and 914 not 911. If they were 911 the splined hole should be bigger so a 914 bar will insert too loose. The stock torsion bars are from Kevin (Rhodyguy).
I realized I had the L & R bars switched so I corrected them but L bar won't insert on L arm. R bar inserts on both arms. I pounded L bar with a small sledge hammer but it didn't insert much. I soaked the bottom in solvent overnight, no affect. There is no front cap (bottom pic) to remove, is this a different type? These arms were seam welded These arms are powdercoated and prepped for needle bearings so I don't want to find another arm if possible. New strut bushings aren't tight yet... Attached image(s) |
davep |
Jul 1 2008, 07:31 AM
914 Historian Group: Benefactors Posts: 5,156 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If the L bar does not go in, then perhaps it is a 911 bar.
As a side note, some 911 A-arms used for hydro-pneumatic suspensions were not splined at the front since they did not use torsion bars. |
Lo-Fi Version | Time is now: 13th June 2024 - 02:48 AM |
