914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,217 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Yesterday I was painting some parts that required that the paint be heated up to adhere properly. I was using a heat gun on the high setting (1200 degrees). The heat gun started to fall and like a FOOL I went to catch it. I the pain was INTENSE and immediate. I grabbed a can of WD-40 and soaked 3 fingers and the plam of my hand. My thinking was the old wives tale of putting butter on a burn. I was fully expecting to go to the emergency room to have my hand treated.
The WD-40 soaked in and started to relieve the pain. The pain came back a second time so I repeated the soaking. My hand required a third treatment. To my amazement I saw no blistering and the pain had subsided. The area was tender to the touch and red but that was all. I came inside to the house to clean up in case a trip to the doctor was in order but still no blistering. The picture is of my hand this morning. The skin is tight on 3 fingers and my palm but you can not tell they were burned. Ripley's believe it or not? Attached image(s) ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Was it cool when you sprayed it? If you immediately apply cold to a burn (1* or 2*) you will slow down the reaction that causes the skin to blister, hurt, turn red. I would still expect it to slough off some if you killed any skin, but it will likely be less. If it wasnt due to the cooling effects of the WD40, then I dont know what happened.
Lo-Fi Version | Time is now: 13th August 2025 - 05:15 AM |
