914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Yesterday I was painting some parts that required that the paint be heated up to adhere properly. I was using a heat gun on the high setting (1200 degrees). The heat gun started to fall and like a FOOL I went to catch it. I the pain was INTENSE and immediate. I grabbed a can of WD-40 and soaked 3 fingers and the plam of my hand. My thinking was the old wives tale of putting butter on a burn. I was fully expecting to go to the emergency room to have my hand treated.
The WD-40 soaked in and started to relieve the pain. The pain came back a second time so I repeated the soaking. My hand required a third treatment. To my amazement I saw no blistering and the pain had subsided. The area was tender to the touch and red but that was all. I came inside to the house to clean up in case a trip to the doctor was in order but still no blistering. The picture is of my hand this morning. The skin is tight on 3 fingers and my palm but you can not tell they were burned. Ripley's believe it or not? Attached image(s) ![]() |
plymouth37 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest ![]() ![]() |
Wow, I never thought of treating a burn like that. You see my solution is to yell out as many obsenities as possible as loud as I can, followed by kicking the s#!t out of what ever burned me, always worked for me!
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Wow, I never thought of treating a burn like that. You see my solution is to yell out as many obsenities as possible as loud as I can, followed by kicking the s#!t out of what ever burned me, always worked for me! (IMG:style_emoticons/default/av-943.gif) The univeral cure all! |
Lo-Fi Version | Time is now: 13th June 2024 - 02:35 AM |
