Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I recently acquired another 'teener. See video here.
I have a leakdown tester like the one pictured below. The included instructions are pretty worthless. There is a hose extension that screws into the spark plug hole in the head. The other end connects to the gauge. My question is, do I add air from my compressor and use the regulator on the tool to set the leakdown gauge (on the right) to 0% and then connect it to the piece of hose, or do I assembly everything together and then add air? I tried the latter method and used the regulator to adjust the leakdown gauge to 0% and then it never went down. ![]() |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,992 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Oh, make sure the crank can't rotate while you have the cylinder pressurized.
and note where the air leaks from, through the crankcase or intake or exhaust valve. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:02 PM |
