> Cylinder leakdown tester, Simple question
Cevan
post Jul 1 2008, 12:50 PM
I recently acquired another 'teener. See video here.
I have a leakdown tester like the one pictured below. The included instructions are pretty worthless. There is a hose extension that screws into the spark plug hole in the head. The other end connects to the gauge. My question is, do I add air from my compressor and use the regulator on the tool to set the leakdown gauge (on the right) to 0% and then connect it to the piece of hose, or do I assembly everything together and then add air?
I tried the latter method and used the regulator to adjust the leakdown gauge to 0% and then it never went down.
VaccaRabite
post Jul 2 2008, 08:18 AM
En Garde!
QUOTE(Cevan @ Jul 1 2008, 02:50 PM) *
The leak down tester that you have, if it is the HF unit, is next to worthless. I tried two of them, and neither of them would register. When I ponied up and bought a real one, it worked perfectly.
Zach
Cevan   Cylinder leakdown tester   Jul 1 2008, 12:50 PM
Racer Chris   Make sure the cylinder you are testing is at TDC c...   Jul 1 2008, 12:54 PM
SLITS   That's the $39.00 setup from Harbor Freig...   Jul 1 2008, 06:25 PM
Jake Raby   Ensure the engine is warm and test each cylinder a...   Jul 1 2008, 08:25 PM
Racer Chris   Oh, make sure the crank can't rotate while you...   Jul 2 2008, 06:52 AM
Vacca Rabite   I have a leakdown tester like the one pictured be...   Jul 2 2008, 08:18 AM
Jake Raby   I have a leakdown tester like the one pictured b...   Jul 2 2008, 12:12 PM
Cevan   I know that the HF stuff is not high quality, or e...   Jul 2 2008, 12:35 PM
ArtechnikA   I figured that if I bought a good one online for ...   Jul 2 2008, 05:58 PM
vsg914   You can buy a $50 drill press or a $50...   Jul 2 2008, 06:34 PM
Cevan   Quick update: I noticed that the leakdown gauge wa...   Jul 3 2008, 04:37 PM
Vacca Rabite   So I warmed up the motor, connected the gauge, a...   Jul 3 2008, 05:45 PM
Cevan   So I warmed up the motor, connected the gauge, ...   Jul 3 2008, 06:12 PM
Vacca Rabite   Neither of the HF units I had worked that way, but...   Jul 3 2008, 06:17 PM
SLITS   What he said is that he replaced the % leakdown ga...   Jul 3 2008, 06:32 PM
Cevan   What he said is that he replaced the % leakdown g...   Jul 3 2008, 06:38 PM
ArtechnikA   Is 3% to 5% realistic on a '74 2.0 of unknown...   Jul 3 2008, 06:53 PM
Vacca Rabite   What he said is that he replaced the % leakdown g...   Jul 3 2008, 09:37 PM
- Lo-Fi Version Time is now: 1st August 2025 - 01:59 PM
