Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I recently acquired another 'teener. See video here.
I have a leakdown tester like the one pictured below. The included instructions are pretty worthless. There is a hose extension that screws into the spark plug hole in the head. The other end connects to the gauge. My question is, do I add air from my compressor and use the regulator on the tool to set the leakdown gauge (on the right) to 0% and then connect it to the piece of hose, or do I assembly everything together and then add air? I tried the latter method and used the regulator to adjust the leakdown gauge to 0% and then it never went down. ![]() |
Cevan |
Quick update: I noticed that the leakdown gauge was getting pegged (0% leakdown) when I had only 15 psi into the cylinder. So I replaced the leakdown gauge with a regular 100 psi gauge. I tested the gauge by putting 100 psi to the gauge and both needles swept to max together.
So I warmed up the motor, connected the gauge, added 100 psi to the cylinder and the leakdown gauge read 97 psi. The other three cylinders read 97, 96, and 95. Now I know that's not a race motor sitting in there, so I think I'm still without useful data on this motor. Maybe the PO before the guy I bought it from had just rebuilt the motor and it's got no miles on it. (IMG:style_emoticons/default/confused24.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,765 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
So I warmed up the motor, connected the gauge, added 100 psi to the cylinder and the leakdown gauge read 97 psi. The other three cylinders read 97, 96, and 95. Now I know that's not a race motor sitting in there, so I think I'm still without useful data on this motor. Are you sure it said 97 PSI? The leak down dial is a percentage, as in 97% leak (goal being under 20%). In general, 0 = no leak at all. 100 means there is no seal at all. If you really have leak numbers in the high 90s, and the gauge is not broken, then there are issues. I have to think that the gauge is wrong, as I don't even thing the engine would run with that high amount of leak... If the leak gauge is reading 97 PSI, that tells you nothing. Zach |
Lo-Fi Version | Time is now: 1st August 2025 - 01:52 PM |
