> Cylinder leakdown tester, Simple question
Cevan
post Jul 1 2008, 12:50 PM
I recently acquired another 'teener. See video here.
I have a leakdown tester like the one pictured below. The included instructions are pretty worthless. There is a hose extension that screws into the spark plug hole in the head. The other end connects to the gauge. My question is, do I add air from my compressor and use the regulator on the tool to set the leakdown gauge (on the right) to 0% and then connect it to the piece of hose, or do I assembly everything together and then add air?
I tried the latter method and used the regulator to adjust the leakdown gauge to 0% and then it never went down.
SLITS
post Jul 3 2008, 06:32 PM
"This Utah shit is HARSH!"
What he said is that he replaced the % leakdown gauge with a regular 100 psi gauge.
So 100 in, 97 left = 3% leak down ... damn good number.
Cevan
post Jul 3 2008, 06:38 PM
QUOTE(SLITS @ Jul 3 2008, 08:32 PM) *
Is 3% to 5% realistic on a '74 2.0 of unknown condition?
ArtechnikA
post Jul 3 2008, 06:53 PM
rich herzog
QUOTE(Cevan @ Jul 3 2008, 08:38 PM) *
yes - because it is unknown.
OTOH, now that you have ~4% it is no longer unknown, and therefore suspect (IMG:style_emoticons/default/smile.gif)
Seriously - it is but ONE bit of information.
The compression-gauge number is another data point. An engine can have excellent leakdown but bad compression and still be undesirable as a street engine. (One possibility being a high-overlap race cam.)
An engine can have good leakdown and -still- need a rebuild if the cam is flat because the lifters went bad.
Or - you could have good leakdown because the rings are rusted in place :-) We'll assume that't not the case.
(Call it) 4% is good. Take your miracles one at a time and be happy.
Put it this way - you're either going to tear the engine down or you're not. I think you'd be silly to tear down a 2,0 914 engine without running it first but be aware there is an argument to be made that the only appropriate thing to be done is tear it down and be sure. That course of action is more work and money, but it does not risk as many broken parts.
You roll the dice and live with the consequences.
Cevan   Cylinder leakdown tester   Jul 1 2008, 12:50 PM
Racer Chris   Make sure the cylinder you are testing is at TDC c...   Jul 1 2008, 12:54 PM
SLITS   That's the $39.00 setup from Harbor Freig...   Jul 1 2008, 06:25 PM
Jake Raby   Ensure the engine is warm and test each cylinder a...   Jul 1 2008, 08:25 PM
Racer Chris   Oh, make sure the crank can't rotate while you...   Jul 2 2008, 06:52 AM
Vacca Rabite   I have a leakdown tester like the one pictured be...   Jul 2 2008, 08:18 AM
Jake Raby   I have a leakdown tester like the one pictured b...   Jul 2 2008, 12:12 PM
Cevan   I know that the HF stuff is not high quality, or e...   Jul 2 2008, 12:35 PM
ArtechnikA   I figured that if I bought a good one online for ...   Jul 2 2008, 05:58 PM
vsg914   You can buy a $50 drill press or a $50...   Jul 2 2008, 06:34 PM
Cevan   Quick update: I noticed that the leakdown gauge wa...   Jul 3 2008, 04:37 PM
Vacca Rabite   So I warmed up the motor, connected the gauge, a...   Jul 3 2008, 05:45 PM
Cevan   So I warmed up the motor, connected the gauge, ...   Jul 3 2008, 06:12 PM
Vacca Rabite   Neither of the HF units I had worked that way, but...   Jul 3 2008, 06:17 PM
SLITS   What he said is that he replaced the % leakdown ga...   Jul 3 2008, 06:32 PM
Cevan   What he said is that he replaced the % leakdown g...   Jul 3 2008, 06:38 PM
ArtechnikA   Is 3% to 5% realistic on a '74 2.0 of unknown...   Jul 3 2008, 06:53 PM
Vacca Rabite   What he said is that he replaced the % leakdown g...   Jul 3 2008, 09:37 PM
- Lo-Fi Version Time is now: 1st August 2025 - 02:02 PM
