VW Type 1 into 914, What are your thoughts? |
james2 |
Jul 4 2008, 12:32 PM
Member Group: Members Posts: 97 Joined: 28-June 08 From: Georgia Member No.: 9,225 Region Association: None |
I have a 2332cc Type 1 engine. It dyno'd at 210 hp and 200 ft-lbs of torque on jake Raby's dyno.
Would I be viewed as a total hack if i put this in a 914? |
Jake Raby |
Jul 4 2008, 01:58 PM
James, You should do it..
The biggest challenge will be cooling it, since the TI has 26% less cooling surface area than that of the TIV and the 914 is typically 600 pounds heavier than a beetle with much taller gearing.. With these 3 negative aspects, not even the DTM you have from me on that engine will be adequate, more than likely.. Twin plugs will help... The first production twin plug TIs are leaving Heaven in about 3 weeks :-) |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:43 PM |
