Okay, help with my motor, was: "carb dial in help? (webber IDF 44)" |
VaccaRabite |
Jul 5 2008, 12:31 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
*edit* Note, cylinder bank 3/4 is not firing. Plugs are oil fouled. All four cylinders have decent compression, considering that the rings probably are not set yet. Carbs are fresh rebuilt, I have yet to check spark.*/edit*
I have set my idle at 1K rpm. Idle adjustment screws for the 3/4 bank is almost all the way out. Idle adjustment screw for 1/2 bank several turns in. Both carbs are idling at 5 kg/h according to my flow meter. Mix screws for all 4 carbs are 2.5 turns open. When I open the throttle to ~3K rpm, the 3/4 bank only sucks slightly more air. The 1/2 bank jumps up to about 15 kg/h. So, where am I off. I have my weber tech manual too, but thought I would ask here to see if I got a faster "ah-ha" type answer (like usual). |
ArtechnikA |
Jul 5 2008, 01:21 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:11 PM |
