| nebreitling |
Jan 4 2004, 03:38 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
being equal parts idiot and newbie, i've got myself into a bit of a predicament. basically, my dizzy is off 90degrees from TDC.
last month, i pulled my distributor out to install a crane xr700 and just do a bit of general cleaning, greasing, etc. i lined up the rotor over the mark on the dizzy body (~TDC) before pulling it. i didnt bother to check for TDC on the fan, thought i'd be close enough. i completed the installs and cleaning, etc. put the dizzy back in. cranked it, didn't start. i'd forgoten to plug in the FI points. tried again, nothing. pulled the dizzy, messed with it, replaced it-->nothing. then i had to leave the country. now i'm back messing w/ it, and have resolved to get it done right. i found TDC by the scribe on the flywheel, confirmed it at the impeller, and then opened up my distributor cap. whoa!: the rotor was pointing 90degrees foward from TDC; i.e. it was pointing at wire 4. the distributor body is oriented correctly, with the vacuum unit pointing towards the drivers side, the #1 wire at the front left, etc. how the hell did i do this? how can i fix it? (IMG:style_emoticons/default/headbang.gif) thanks in advance (no pun intended) for your replies.... nathan sorry, no camera; no pics. |
| Curvie Roadlover |
Jan 4 2004, 07:31 PM
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Mark (IMG:style_emoticons/default/clap56.gif)
nebreitling Long, sordid tale w/ a question at end Jan 4 2004, 03:38 PM
nebreitling okay, i'm guessing that my distributor drive s... Jan 4 2004, 04:01 PM
fiid errr... can't you just re-plug the wires into ... Jan 4 2004, 05:19 PM
nebreitling
fiid I reckon you're plugged in wrong. I think if ... Jan 4 2004, 05:43 PM
nebreitling huh. maybe. i double checked my plug wires ... Jan 4 2004, 06:07 PM
McMark It's actually pretty easy. Once you've do... Jan 4 2004, 06:15 PM
nebreitling Mark, you are my hero. :worship:
seriously. t... Jan 4 2004, 07:16 PM
Gint Those are some really nice pics Mark. Classic thr... Jan 4 2004, 07:23 PM
nebreitling that's what i was thinking... if an admin cou... Jan 4 2004, 07:25 PM
Gint Let the thread play out. Jan 4 2004, 07:27 PM
rhodyguy good job mark.
kevin Jan 4 2004, 07:45 PM
McMark Thanks for the compliments. Sometimes I get inspi... Jan 4 2004, 09:06 PM
redshift That is an excellent write up, with pics..
There ... Jan 4 2004, 09:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 07:55 PM |
