Align Boring the Crankcase, Help educate this amateur... |
stephenaki |
Jul 15 2008, 03:33 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I understand the reason WHY you align bore the case, got it. My question with the 914 case is bearing selection after it is done.
Now, rebuilding my MG engine and selecting bearings was easy, measure the journals and choose the size needed. The 914 case however has a set on the journal and a set on the case. If I have to align bore the case is there a special consideration on bearing selection or do I just measure journals and get a bearing set that accounts for the difference based on balancing of the crank. May be an obvious question to some but I am confused and want to make sure I rebuild the engine correctly and order the right parts. |
hcdmueller |
Jul 15 2008, 08:07 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
vsq914, I think you are right.
From what I can tell you either get different bearings for your turned down crankshaft or bearings for your alignbored case. I don't know if there are bearings that will accomadate both. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:06 AM |
