Align Boring the Crankcase, Help educate this amateur... |
stephenaki |
Jul 15 2008, 03:33 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I understand the reason WHY you align bore the case, got it. My question with the 914 case is bearing selection after it is done.
Now, rebuilding my MG engine and selecting bearings was easy, measure the journals and choose the size needed. The 914 case however has a set on the journal and a set on the case. If I have to align bore the case is there a special consideration on bearing selection or do I just measure journals and get a bearing set that accounts for the difference based on balancing of the crank. May be an obvious question to some but I am confused and want to make sure I rebuild the engine correctly and order the right parts. |
stephenaki |
Jul 16 2008, 02:51 AM
Thanks all, the crank that I ordered is balanced as are the rods, I don't remember the measurement I was given.
I recieved my pistons and cylinders yesterday, 94mm, and once I get my crank and rods in I will have everything balanced. I am hoping to have the case checked for alignment this week but may have to wait until the first week in August as all the Germans are getting ready to go on vacation and usually nothing is open! Will update my other thread when I get things checked and ready for re-assembly. Always nice to have people smarter and more experienced provide input. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:26 AM |
