2.0 Head CC, Stock Volume? |
Todd Enlund |
Jul 21 2008, 05:31 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I just CCed one of my heads. I got 62cc in both chambers. I thought that stock was 60cc? Does this mean that the buret that I bought is a POS?
By my math, 62cc chambers would give me 9.2:1 with a .040 deck height on a 96x78 mm 2258cc engine... 60cc would give me 9.4:1. Heads need a rebuild... I'm just trying to figure out where I'm at for a starting point. |
HAM Inc |
Jul 22 2008, 07:59 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
The largest O.E. chamber I can recall measuring came in around 61cc's. Most unatlered OE chambers come in around 58cc's.
Todd if you are getting consistent repeatability, then your method is probably good. I use wintergreen rubbing alcohol. Cheap and cleans up easy. Make sure that you purge the valve of air before measuring. These chambers were sent from the factory in as cast condition, and they do vary. A 62cc chamber is not tough for me to believe. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:44 AM |
