tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
How easy is it to break the lines on the stock oil coolers? The reason I ask is because I have a pretty significant oil leak from the cooler. I had just installed the engine and cooler with new seals. I have checked all of the other normal oil leak locations and they are all ok (sender, plugs...). It clearly is from the cooler. The leak is significant.
I changed the seals a few days ago and the leak is exactly the same as it was. When I installed the cooler when I rebuilt me engine, I wasn't paying attention and put the cooler studs into the fins and not through the correct holes. It went through pretty easily. Is it possible that I broke the cooler from doing this? I find it hard to believe that my seals are bad considering that I just changed them again. |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
hate to suggest this but... (IMG:style_emoticons/default/stromberg.gif) you may want to remove it and pressurize the cooler with regulated air pressure. check for a leak with no more than air press than max. oil pressure while dipping it in water to look for bubbles. sounds like it'll show up easily if it's the obvious bad oil leak.
mike |
Lo-Fi Version | Time is now: 6th July 2025 - 07:09 PM |
