worked on the Sporto today - with success, thanks to Andy for his input |
Gustl |
Jul 27 2008, 09:38 AM
914 enthusiast & historian Group: Members Posts: 11,527 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
Today my plan was to find out more about my shifting problems. Therefor I decided to substitute the shiftstick-microswitch with a manual operated switch, to see if this would solvve the problem.
As it turned out, I was really not well prepared ... I had hardly anything useful at home to do this work. So I had to improvize a little. I took an old spotlight that I didn't use for at least 8 years or so and checked if it still worked fine - and it did. So I dismounted the switch to use it as a microswitch substitut. Because I had no wires at home, I had to cut out a little less that 2 feet of the speaker wires of my stereo (IMG:style_emoticons/default/blink.gif) When I started to lift the shift boot I saw that anybody already worked on this problem. The wires were already cut and clamped together. That's nice - so I didn't need to disturb original material (IMG:style_emoticons/default/biggrin.gif) I took my DMM to check if the microswitch could be the problem and it turned out that it didn't switch in the way it should. This is s very tricky thing - at least for me. |
BarberDave |
Jul 27 2008, 12:02 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Gust & Hcdmueller, You both have just regressed 2 steps in the 914, 12 step program! Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 01:17 PM |
