Push or Pull? Which way would you install?, Holley Electric Blue |
computers4kids |
Jul 27 2008, 10:15 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I have a Holley blue electric fuel pump that I would like to install in my 75 v-8 conversion. I am trying to decide the best location to install it.
Choice 1: Install it near the stock location up front in the trunk mounting it on the wall that encloses the gas tank facing inward towards the trunk for easy accessibility. Gravity fed from tank and regulated up front also so the lines going back to the carb are only pressurized to 5lbs. Wiring is already there. + easy install and wiring is already there - lines pressurized length of car + cooler in front trunk, even with radiator, than engine compartment Choice 2: Install it in the engine compartment somewhere on the passenger side. The pump would be gravity fed the length of the car and then pressurized and regulated in the engine bay. I would have to run a wire for to power it up. + gravity fed so lines are not under pressure in tunnel - not sure if pump will work as well trying to pull rather than push - hotter in engine compartment What would be the better approach? Thanks Attached image(s) |
Joe Bob |
Jul 27 2008, 10:18 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Leave it up front if the power and mounting hardware is already there. I'm a fan of recirculating even if you have carbs....
orange914 |
Jul 27 2008, 05:07 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Leave it up front if the power and mounting hardware is already there. I'm a fan of recirculating even if you have carbs.... up front... (IMG:style_emoticons/default/agree.gif) +++cooler! just a crazy, maybe overkill way but maybe you could pre-regulate it (in front) down to ...say... 10 p.s.i. before your final regulator at the carbs if you have concerns. i'll bet you have an extra regulator to loop the excess back on a front reg. you are looping (or returning) the fuel from the rear? i had a complete pump/reg set up from a parted out 914 i wanted to run on my 69 ranchero but i ended up selling the truck first. mike |
Lo-Fi Version | Time is now: 9th June 2024 - 11:41 PM |
