Push or Pull? Which way would you install?, Holley Electric Blue |
computers4kids |
Jul 27 2008, 10:15 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I have a Holley blue electric fuel pump that I would like to install in my 75 v-8 conversion. I am trying to decide the best location to install it.
Choice 1: Install it near the stock location up front in the trunk mounting it on the wall that encloses the gas tank facing inward towards the trunk for easy accessibility. Gravity fed from tank and regulated up front also so the lines going back to the carb are only pressurized to 5lbs. Wiring is already there. + easy install and wiring is already there - lines pressurized length of car + cooler in front trunk, even with radiator, than engine compartment Choice 2: Install it in the engine compartment somewhere on the passenger side. The pump would be gravity fed the length of the car and then pressurized and regulated in the engine bay. I would have to run a wire for to power it up. + gravity fed so lines are not under pressure in tunnel - not sure if pump will work as well trying to pull rather than push - hotter in engine compartment What would be the better approach? Thanks Attached image(s) |
computers4kids |
Jul 27 2008, 10:26 PM
that pump is not a high pressure pump, so no worries on the stock plastic lines there rated at much higher than the holley will put out. it's volume that the holley does good. get a regulator that is ment for a return system and run it right up to the carb. that holley is good but the generic jeggs and summit will do fine and at 30 % discount. Thanks for the tip...but too late. Picked up a new blue and reg. for $75...so I'm happy. True about the pressure...Holley is set at 14 and we know the FI lines were generally running 29 lbs. I'll have to see what I can find for a regulator that returns. |
messix |
Jul 27 2008, 11:44 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
that pump is not a high pressure pump, so no worries on the stock plastic lines there rated at much higher than the holley will put out. it's volume that the holley does good. get a regulator that is ment for a return system and run it right up to the carb. that holley is good but the generic jeggs and summit will do fine and at 30 % discount. Thanks for the tip...but too late. Picked up a new blue and reg. for $75...so I'm happy. True about the pressure...Holley is set at 14 and we know the FI lines were generally running 29 lbs. I'll have to see what I can find for a regulator that returns. great find at that price. here's a reg that will work on return http://store.summitracing.com/partdetail.a...mp;autoview=sku |
Lo-Fi Version | Time is now: 9th June 2024 - 10:03 PM |
