> Need Help Removing Steering Rack, Now I Get IT!!!
ericread
post Aug 2 2008, 05:13 PM
The Viper Blue 914
HELP!!! I have read and re-read the prior posts on steering rack replacement. I am at the point where the following has been completed:
1. Removed fuel tank.
2. Removed right and left tie rods.
3. Detatched U-Joint directly inside driver compartment.
4. Removed two bolts that attach steering rack to the support.
5. Removed two bolts that attach support bar to body (off the tabs that face the rear of the car (shown at item 6 in the diagram).
6. Removed the two bolts that attach master cylinder to the bulkhead/pedal cluster.
7. Removed the two bolts that hold the steering shaft bearing (over the steering shaft bellows underneath the fuel tank).
Question 1: How do I move the master cylinder out of the way? The short brake line that goes to the tunnel doesn't give the master cylinder a lot of distance to back off, and the support bar (item #1 in the diagram) is in the way when I pull the master cylinder back.
Question 2: How do I actually remove the rack? The steering shaft directly connected to the rack seems to require that I drop the rack directly down. But the bolt tabs on the support bar itself (Item #1 in the diagram), as well as the bolt tabs that run a few inches to the underside of the body (towards the rear or the body) (item # 6 in the diagram) all seem to be in the way? What am I missing???
My thanks.
Eric Read
Spoke
post Aug 2 2008, 08:04 PM
Jerry
If you disconnect the 2 big bolts holding the crossmember and lower the crossmember, you should be able to pull out the rack.
When I 5-lugged my car, I removed everything, then installed the rack first, then the crossmember.
- Lo-Fi Version Time is now: 16th October 2026 - 09:29 PM
