rear "V-caliper" vs. "M" caliper, please jump in Eric Shea |
Wes V |
Aug 12 2008, 10:28 AM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
In the process of converting to 5 lug and also rear vented rotors, there appears to be two ways to go about it. Both have been explored and written about by Eric Shea over the years. (Ya, I've done a lot of searching and reading)
One is the usage of a late model 914 rear caliper with spacers placed in the body, to get the needed clearance for the vented rotor. (as I read it; a late model ATE caliper is used and not a rare 914/6 caliper) A spacer is required between the brake rotor and hub (moving the rotor and wheel outward). The rotor (911SC) has to have it's diameter shaved down 4mm) The parking brake cable just hooks up as stock. The other option is to use the "M" caliper from a 911 and also the parking brake assembly. Mounting the parking brake assembly requires grinding and welding on the housing. Hooking up the parking brake cable requires fabrication, but is possible (and can be found by searching this site). Now I can think of plus and minus points for both, but I'd like to hear from others. Wes Vann |
Joe Bob |
Aug 12 2008, 11:28 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
OK...braking not parking brake is the issue....unless you are racing and need huge brakes with heat dissipation, the non-vented rotor is fine...you can slot them for more grabbing power....but due to the brake bias....most of your braking comes from your front brakes.
Shaving an SC rotor down is easy the first time, a PITA the next.....you booger up one because a pad takes a dump...you don't have a rotor sitting around to throw on collectiong dust and you need to wait for the machine shop to open up....BTDT. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:50 PM |
