watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I've been trying to track down an electrical problem with my FI and I've found more problems.
1. When I turn on the ignition switch I blow fuse #9. The Haynes manual says that this fuse powers the turn signals, brake lights and back-up lights. Also, I noticed that the buzzer sounds when I turn on the key, regardless of both doors closed or open. Anyway, I disconnected the brake light switch at the brake pedal, all of the wires to the turn signals and disconnected the back-up light wire at the tranny but the fuse still blows, which then stops the buzzer. 2. No power to the coil. I've replaced the ignition switch with another one, but I'm still not getting any power at the coil. I've checked the continuity between the ignition switch and the coil. I have power to all pin #30s on the relay board in the engine compartment. I have power at the large red wire at the ignition switch. I feel that I'm very close to getting this car running, but with these electrical gremlins I'm extremely frustrated...(IMG:style_emoticons/default/mad.gif) Any suggestions and/or guidance would be greatly appreciated.... -- Rob |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
1. When I turn on the ignition switch I blow fuse #9. The Haynes manual says that this fuse powers the turn signals, brake lights and back-up lights. -- Rob sounds like you have a direct short. since the turn/brake lights are in the curcuit, have you messed with the bulbs previous to the problem? a 1156 inserted 180* off will do odd things. how about the 1156 in the 1157 spot or visa-versa? been there, done that, got the t-shirt mike |
Lo-Fi Version | Time is now: 15th July 2025 - 05:39 AM |
