turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Little background first. Bought the car about a month ago and drove it around the neighborhood for a little while since it wasnt insured, never out on actual roads with other drivers. I got the insurance on the car and took it out for its first real drive. Drove the car for about 30 min and stopped at the bank to make a deposit. When i went back out the car would not start, couldn't even jump start the car. So i had to have it towed home, the drive cost me 50 dollars.
Well, i get the car back to the garage and start tearing into it, thinking it might be the starter, well i can't change the starter until the engine comes out(unless someone can help me there) but the starter seems fine, because i replaced the battery and the starter had lots more power. So new battery didn't make the car fire up, only the starter would crank the car, but no actual running engine. Replaced the spark plugs(they were horrible, gaped correctly) didn't do a thing. The starter cranks the engine but it will not fire up. I changed the fuel filter(and some of the fuel lines because they were horrible) today and that didn't help either. The old filter was pretty nasty. Hooked the fuel pump back up and the car still won't fire, starter cranks, but the engine won't turn over and start. I have ordered a new coil and spark plug wires. I had a friend with me and he watched the spark come through the wires and said it was really weak. However, if this doesn't solve my starting problem, what else could there be? My dad says to check the timing and possibly the fuel pump might not even be working. The car ran two weeks ago, is it possible the fuel pump went out? Oh yea, the car originally came with the 2.0L but the PO sold it and put a 1.8L carbed engine in. I can get more info about the engine if it helps. Thanks everybody. Here are some pictures of the car, i am hoping for a 916 clone. I need the rear bumper and thats it(unless i want a steel roof, which i don't) (IMG:http://photos-g.ak.facebook.com/photos-ak-sf2p/v307/98/57/507290528/n507290528_3615990_1068.jpg) (IMG:http://photos-g.ak.facebook.com/photos-ak-sf2p/v307/98/57/507290528/n507290528_3615998_4055.jpg) (IMG:http://photos-b.ak.facebook.com/photos-ak-sf2p/v307/98/57/507290528/n507290528_3616001_4924.jpg) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
you should hear the pump running when you turn the key to the first position. single or dual carbs?
k |
angerosa |
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region ![]() |
you should hear the pump running when you turn the key to the first position. single or dual carbs? k (IMG:style_emoticons/default/agree.gif) Totally - You can't miss this. There should be no doubt that the pump is on. If still have a doubt - you can disconnect the fuel line and run it into a gas can and turn the key to the first position and see if gas flows. You shouldn't even need to do this - you should hear it and there should be no doubt. If your car ran really well when it was running (no back fire, skippng, sudden loss of power). It's most likely an electrical problem. This tells me your carbs are tuned, engine and ignition timing were good. It's rare those things change enough over one ride so that your car just doesn't work at all. It scares me that you're wondering if it's the starter when your engine cranks. Look at condenser, points, cap, rotor, coil and I'll bet you'll find your problem. Weak spark might be condensor or coil. Some things you should know: Your car looks pretty cool. $50 tow is cheap. It could have been much worse. Welcome to owning a 30+ year old car. |
Lo-Fi Version | Time is now: 6th July 2025 - 04:24 PM |
