r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So, how much weight is one HP??
Meaning...If I remove XXX lbs its the same as gaining YY HP Rich |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Your question is very parallel to the old LBJ:
Q: How many Surrealists does it take to change a lightbulb? A: FIIIIIIIISH! The only way you can convert lbs to HP is by throwing in length (feet) and time (minutes). Divide the weight in lbs by the length in feet and by the time in minutes. Throw in a term for revolution as well, and you have HP. Re-arrange it, and you get: HP = lbs/ft * R/min [ * 5252 to get the units right] Which is an obnoxious way of saying that your question has no real answer. Too many other factors for any one number to be "correct". For instance, take 100 lbs off of a BMW 7-series. Not much diff, huh? Now take it off of a motorcycle. Big big diff!! Also, lighter weight means less force required to accelerate, or decelerate, or turn. More HP does nothing for braking or turning, so at an autoX light weight is even more important than at the drag strip, for instance. --DD |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:15 PM |
