tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I have recently gotten my 914 up and running after a rebuild. I have been trying to work on the carbs and timing. The car runs ok but I am shooting black soot out of the exhaust and the exhaust backfires on decel. Engine idles fine. I have been reading and searching for a long time. I have read too much and I am now super confused. I keep reading that the backfiring on decel is from a lean condition and the black soot is from mixture being too rich? I am confused, can anybody help me? To confuse me more, I recently saw some white/blue smoke- I checked my compression and I am getting 150 in all cylinders.
car info -73' 1.7 liter however I now have 96mm jugs, 78.5mm stroker crank- making engine displacement just under 2.4l. -the previous owner put in a new camshaft however I do not know the details other than that it is from webcam -2.0 heads -cromoly pushrods with clearance set to 0 cold -timing set at 27 degrees at 3000 rpm -bosch 050 dizzy with pertronix -msd 6al carb info (all the jet/venturi/etc sizes were placed by the previous owner) -dual weber 40 idf's -carbs just rebuilt last week -32 main venturi's -120 main jets -f7.5 emulsion tubes -200 air correction jets I am so confused. Your help is greatly appreciated, Steve |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
1st of all NEVER trust what the internet Yahoos say.
Most of the above is pure crap. Now to know exactly what you have there needs to be some more details of the engine. Heads and exhaust compression ratio. Spark plug gap and type of coil and wires. all these things greatly affect the tune of a motor. Now it really doesn't matter what is stamped on the jet. I suspect your engine would not even run on 120 jets. NO EFFING WAY............ So somebody had to have reamed out your jets. Also you can probably back off on your acceleration jet stroke linkage. |
Lo-Fi Version | Time is now: 5th July 2025 - 02:21 AM |
