> Another Carb/Timing Question, I am really not good at this stuff
tornik550
post Aug 24 2008, 05:55 PM
I have recently gotten my 914 up and running after a rebuild. I have been trying to work on the carbs and timing. The car runs ok but I am shooting black soot out of the exhaust and the exhaust backfires on decel. Engine idles fine. I have been reading and searching for a long time. I have read too much and I am now super confused. I keep reading that the backfiring on decel is from a lean condition and the black soot is from mixture being too rich? I am confused, can anybody help me? To confuse me more, I recently saw some white/blue smoke- I checked my compression and I am getting 150 in all cylinders.
car info
-73' 1.7 liter however I now have 96mm jugs, 78.5mm stroker crank- making engine displacement just under 2.4l.
-the previous owner put in a new camshaft however I do not know the details other than that it is from webcam
-2.0 heads
-cromoly pushrods with clearance set to 0 cold
-timing set at 27 degrees at 3000 rpm
-bosch 050 dizzy with pertronix
-msd 6al
carb info (all the jet/venturi/etc sizes were placed by the previous owner)
-dual weber 40 idf's
-carbs just rebuilt last week
-32 main venturi's
-120 main jets
-f7.5 emulsion tubes
-200 air correction jets
I am so confused.
Your help is greatly appreciated,
Steve
r_towle
post Aug 24 2008, 09:33 PM
Custom Member
Make sure you listen to Joe, he knows everything.
Rich
tornik550   Another Carb/Timing Question   Aug 24 2008, 05:55 PM
r_towle   Well, you probably have two issues. Backfiring ou...   Aug 24 2008, 06:08 PM
tornik550   I will look for the exhaust leak. Any good ideas ...   Aug 24 2008, 06:33 PM
SirAndy   I am so confused. Like rich said, backfire throug...   Aug 24 2008, 07:08 PM
r_towle   to find the leak put a 2*4 over the exhit tailpipe...   Aug 24 2008, 07:12 PM
tornik550   it appears that my idle jets are 50   Aug 24 2008, 07:48 PM
r_towle   I would say first fix the exhaust leak. I had 40m...   Aug 24 2008, 08:00 PM
904svo   With the Weber 40's , I would suggest you chan...   Aug 24 2008, 08:11 PM
tornik550   where can you get 38mm vents for a 40idf? i just ...   Aug 24 2008, 08:54 PM
Joe Ricard   1st of all NEVER trust what the internet Yahoos sa...   Aug 24 2008, 09:20 PM
roadster fan   1st of all NEVER trust what the internet Yahoos s...   Aug 25 2008, 01:06 PM
r_towle   Now it really doesn't matter what is stamped ...   Aug 25 2008, 02:32 PM
r_towle   Make sure you listen to Joe, he knows everything. ...   Aug 24 2008, 09:33 PM
Joe Ricard   See at least Rich knows who's the "Mac Da...   Aug 25 2008, 07:27 AM
Joe Ricard   What you still can't read? You even re-posted...   Aug 25 2008, 02:47 PM
wertygrog   JETS size as in main jet size of 120 will not r...   Aug 25 2008, 10:25 PM
r_towle   JETS size as in main jet size of 120 will not ...   Aug 25 2008, 10:28 PM
r_towle   I know you like picking a fight, but read what I w...   Aug 25 2008, 03:34 PM
Joe Ricard   That would be one heck of a starter to spin a moto...   Aug 25 2008, 09:16 PM
SGB   It has been a long time, but I thought (ouch) that...   Aug 25 2008, 10:40 PM
Joe Ricard   Yea I have had a 2.0L engine for many years. Low ...   Aug 26 2008, 06:20 AM
r_towle   I guess after rebuilding three motors you are the ...   Aug 26 2008, 08:16 AM
- Lo-Fi Version Time is now: 5th July 2025 - 02:35 AM
