> front wheels, can't get them off
level914
post Jan 8 2004, 04:14 PM
O.k, I must be a moron. Is there a trick to getting the front wheels off? They are 2.0 liter Fuchs if that means anything. I have removed the lug bolts and center cap. By the way, is there an easy way to remove center caps that have not been removed for a long time?
ArtechnikA
post Jan 8 2004, 04:36 PM
rich herzog
maybe squirt some PB Blaster into the bolt holes and hub circle and hope it can creep in and break the corrosion.
i really extreme circumstances i've heard of people removing the hub cover, pinch bolt, and compression nut and pulling the whole hub off the spindle. you might have more options at that point, but we will hope it doesn't come to that point ...
level914   front wheels   Jan 8 2004, 04:14 PM
vsg914   How long have they been on? They could be rusted t...   Jan 8 2004, 04:28 PM
level914   They have been on for, my guess, 10-15 years. Wou...   Jan 8 2004, 04:35 PM
ArtechnikA   maybe squirt some PB Blaster into the bolt holes a...   Jan 8 2004, 04:36 PM
SirAndy   BFH :smash:   Jan 8 2004, 04:37 PM
!   Whack the inside of the wheel on the tires....use ...   Jan 8 2004, 04:37 PM
iiibdsiil   I have in the past kicked it a couple times hard a...   Jan 8 2004, 04:41 PM
Brian_Boss   If none of the above works and the car is driveabl...   Jan 8 2004, 04:42 PM
level914   Thanks guys, as soon as my daughter wakes up from ...   Jan 8 2004, 04:45 PM
ChrisReale   If your wheels are stuck on, wait until you try to...   Jan 8 2004, 04:46 PM
914ghost   As a LAST resort, if after you've pounded from...   Jan 8 2004, 04:51 PM
level914   Robert, my uncle actually used the same method but...   Jan 8 2004, 05:07 PM
Rgreen914   level914 You sound like you're going to fit r...   Jan 8 2004, 05:24 PM
vsg914   Ok, you got the wheels off. Next remove the rocker...   Jan 8 2004, 05:42 PM
Aaron Cox
- Lo-Fi Version Time is now: 16th July 2025 - 04:01 PM
