jesiv |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California ![]() |
Ok I am starting to play. So I purchased the complete suspension from a drilled 5 lug conversion (complete front including rack and rear trailing arms with drilled 5 lug hub). My plan was to buy a sway bar, tubro tie rods, koni adjustable and then replace entire front suspension. I thought I was clear on what I was going to do.
Today I found a great deal on a freshly rebuilt 72 911 front suspension with 911 sway bar and torsion bars. It is a complete suspension minus steering rack and tie rods. So I am thinking I should install the 911 stuff. Or should I mix and match parts. (IMG:style_emoticons/default/dry.gif) The 911 brakes sure look nice (IMG:style_emoticons/default/piratenanner.gif) Also would you get 15 or 16 fuchs? (IMG:style_emoticons/default/WTF.gif) Regards, James |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
The U-tabs can be added to any arms, so that's not a problem. I replaced the struts on my car with early 80s Carrera struts and brakes, but I'd just look around and see what you can find with a good price. These parts are all pretty much interchangeable, and there is no real advantage to -4 or -6 arms other than the number of splines on the torsion bars. The same with the crossmember, the aluminum one is not that much different than the early steel ones.
Lo-Fi Version | Time is now: 16th June 2024 - 12:15 AM |
