> front wheels, can't get them off
level914
post Jan 8 2004, 04:14 PM
O.k, I must be a moron. Is there a trick to getting the front wheels off? They are 2.0 liter Fuchs if that means anything. I have removed the lug bolts and center cap. By the way, is there an easy way to remove center caps that have not been removed for a long time?
level914
post Jan 8 2004, 05:07 PM
Robert, my uncle actually used the same method but with a rock to remove a tooth. Brought him to his knees faster than anything I had ever seen. Brains aint big in my family.
Anyway the, big hammer worked like a charm. Also dumped about 3 pounds of dirt from my rocker panel on my head.
Thanks everybody!
level914   front wheels   Jan 8 2004, 04:14 PM
vsg914   How long have they been on? They could be rusted t...   Jan 8 2004, 04:28 PM
level914   They have been on for, my guess, 10-15 years. Wou...   Jan 8 2004, 04:35 PM
ArtechnikA   maybe squirt some PB Blaster into the bolt holes a...   Jan 8 2004, 04:36 PM
SirAndy   BFH :smash:   Jan 8 2004, 04:37 PM
!   Whack the inside of the wheel on the tires....use ...   Jan 8 2004, 04:37 PM
iiibdsiil   I have in the past kicked it a couple times hard a...   Jan 8 2004, 04:41 PM
Brian_Boss   If none of the above works and the car is driveabl...   Jan 8 2004, 04:42 PM
level914   Thanks guys, as soon as my daughter wakes up from ...   Jan 8 2004, 04:45 PM
ChrisReale   If your wheels are stuck on, wait until you try to...   Jan 8 2004, 04:46 PM
914ghost   As a LAST resort, if after you've pounded from...   Jan 8 2004, 04:51 PM
level914   Robert, my uncle actually used the same method but...   Jan 8 2004, 05:07 PM
Rgreen914   level914 You sound like you're going to fit r...   Jan 8 2004, 05:24 PM
vsg914   Ok, you got the wheels off. Next remove the rocker...   Jan 8 2004, 05:42 PM
Aaron Cox
- Lo-Fi Version Time is now: 16th July 2025 - 04:42 PM
