> Another Carb/Timing Question, I am really not good at this stuff
tornik550
post Aug 24 2008, 05:55 PM
I have recently gotten my 914 up and running after a rebuild. I have been trying to work on the carbs and timing. The car runs ok but I am shooting black soot out of the exhaust and the exhaust backfires on decel. Engine idles fine. I have been reading and searching for a long time. I have read too much and I am now super confused. I keep reading that the backfiring on decel is from a lean condition and the black soot is from mixture being too rich? I am confused, can anybody help me? To confuse me more, I recently saw some white/blue smoke- I checked my compression and I am getting 150 in all cylinders.
car info
-73' 1.7 liter however I now have 96mm jugs, 78.5mm stroker crank- making engine displacement just under 2.4l.
-the previous owner put in a new camshaft however I do not know the details other than that it is from webcam
-2.0 heads
-cromoly pushrods with clearance set to 0 cold
-timing set at 27 degrees at 3000 rpm
-bosch 050 dizzy with pertronix
-msd 6al
carb info (all the jet/venturi/etc sizes were placed by the previous owner)
-dual weber 40 idf's
-carbs just rebuilt last week
-32 main venturi's
-120 main jets
-f7.5 emulsion tubes
-200 air correction jets
I am so confused.
Your help is greatly appreciated,
Steve
Joe Ricard
post Aug 24 2008, 09:20 PM
CUMONIWANNARACEU
1st of all NEVER trust what the internet Yahoos say.
Most of the above is pure crap.
Now to know exactly what you have there needs to be some more details of the engine.
Heads and exhaust compression ratio.
Spark plug gap and type of coil and wires.
all these things greatly affect the tune of a motor.
Now it really doesn't matter what is stamped on the jet. I suspect your engine would not even run on 120 jets. NO EFFING WAY............
So somebody had to have reamed out your jets.
Also you can probably back off on your acceleration jet stroke linkage.
roadster fan
post Aug 25 2008, 01:06 PM
Project Frankenstein !!!!!!!!
QUOTE(Joe Ricard @ Aug 24 2008, 08:20 PM) *
Hey, doesn't posting here make you an internet Yahoo Joe? (IMG:style_emoticons/default/av-943.gif)
Seriously tho, there are alot of people here that can help you get it running right. Do all your research before you start swapping parts.
Jim
tornik550   Another Carb/Timing Question   Aug 24 2008, 05:55 PM
r_towle   Well, you probably have two issues. Backfiring ou...   Aug 24 2008, 06:08 PM
tornik550   I will look for the exhaust leak. Any good ideas ...   Aug 24 2008, 06:33 PM
SirAndy   I am so confused. Like rich said, backfire throug...   Aug 24 2008, 07:08 PM
r_towle   to find the leak put a 2*4 over the exhit tailpipe...   Aug 24 2008, 07:12 PM
tornik550   it appears that my idle jets are 50   Aug 24 2008, 07:48 PM
r_towle   I would say first fix the exhaust leak. I had 40m...   Aug 24 2008, 08:00 PM
904svo   With the Weber 40's , I would suggest you chan...   Aug 24 2008, 08:11 PM
tornik550   where can you get 38mm vents for a 40idf? i just ...   Aug 24 2008, 08:54 PM
Joe Ricard   1st of all NEVER trust what the internet Yahoos sa...   Aug 24 2008, 09:20 PM
roadster fan   1st of all NEVER trust what the internet Yahoos s...   Aug 25 2008, 01:06 PM
r_towle   Now it really doesn't matter what is stamped ...   Aug 25 2008, 02:32 PM
r_towle   Make sure you listen to Joe, he knows everything. ...   Aug 24 2008, 09:33 PM
Joe Ricard   See at least Rich knows who's the "Mac Da...   Aug 25 2008, 07:27 AM
Joe Ricard   What you still can't read? You even re-posted...   Aug 25 2008, 02:47 PM
wertygrog   JETS size as in main jet size of 120 will not r...   Aug 25 2008, 10:25 PM
r_towle   JETS size as in main jet size of 120 will not ...   Aug 25 2008, 10:28 PM
r_towle   I know you like picking a fight, but read what I w...   Aug 25 2008, 03:34 PM
Joe Ricard   That would be one heck of a starter to spin a moto...   Aug 25 2008, 09:16 PM
SGB   It has been a long time, but I thought (ouch) that...   Aug 25 2008, 10:40 PM
Joe Ricard   Yea I have had a 2.0L engine for many years. Low ...   Aug 26 2008, 06:20 AM
r_towle   I guess after rebuilding three motors you are the ...   Aug 26 2008, 08:16 AM
- Lo-Fi Version Time is now: 5th July 2025 - 03:40 AM
