DarrenG |
Newbie ![]() Group: Members Posts: 46 Joined: 20-May 08 From: Liberty, MO Member No.: 9,078 Region Association: Upper MidWest ![]() |
Bad day.
Took the teener ('74 2.0) for a test drive last night. first trip since the rebuild. Made it almost 3 miles. struggled to keep it from stalling, managed to get it up to 60, then total loss of power. Couldn't even get up a hill - towed home. She had all the signs of a blown MPS: extremely rich, hard to start. This is getting old. Options: Try to find a reasonable, decent MPS. Switch to carbs - which I am seriously considering because I've had to fix broken wires on the harness 4 times already. When it has run (400 miles in a year) I had to constantly feather the pedal to keep it from losing power (another problem?). Just wondering how much this old FI system has left. I don't want to go too high end, because I'm upside down in this car already. I am not trying to restart the carb vs. EFI debate. So, I'll stick with one specific question: Are dual Weber 34 ICT's sufficient for a 2056? This is a daily driver (hopefully), but I also don't want to get passed by some old lady in a miata. Thanks for the advice. D |
Gene |
Newbie ![]() Group: Members Posts: 44 Joined: 19-August 08 From: Louisville, KY Member No.: 9,441 Region Association: South East States ![]() |
I'm going the route of just building my own megasquirt 2 system. No more vacuum issues and then I'll time it with the Ford Edis system. Under a grand total and I can fix every bit of it quickly. I prefer circuits to mechanical things like vacuum and points. For the money you'd spend on carbs you could buy the premade megasquirt 2 system and throw on an electronic distributor (crane optical/pertronix 2, etc) and have pretty much the same fuel injection attributes you get with the stock system when it's working and much less wear/possible failures.
Lo-Fi Version | Time is now: 17th July 2025 - 05:12 AM |
