Thinking Megasquirt again, on the /6, Blame Excellence |
Dr Evil |
Aug 25 2008, 07:39 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Scotty B let me read his copy of the latest Excellence where they put a MS derived injection system and put it on a 6cyl motor. The kit was from Bitz Racing, cost $1600 and requires some CIS parts. Looking at the kit I am thinking that I can do it for much less. I already have 2 full CIS systems, I can build a MS, and I can buy the fuel system parts independently.
So you figure, $1600 for an install and run kit --> http://www.bitzracing.com/products/index.html Parts cost: - Fuel rail = $10/ft - Their recommended fuel pressure regulator, MSD-2222 = $75 - Their recommended injectors, ACC-150630 = $230 for 6 - MS v.3.0 kit with everything = $200 --> http://www.diyautotune.com/catalog/megasqu...case-p-108.html - Injector adapter bungs = $120 Total = about $650 I have not priced an O2 sensor just yet, though. Hummm (IMG:style_emoticons/default/idea.gif) |
toon1 |
Aug 26 2008, 09:22 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
You can buy the MS-I and run MS&SE code.
i have been running it on mine for about 4k miles with no prob. It's easy to install and easy to use. It's basically like the MS-II, some of the tables are a little different. You will also nee a wire harness (50$), TPS and I highly recommend a relay board. It makes the install easier. Keith |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:03 PM |
