OT. WAY OT, Engineering Problem. Need some help |
jfort |
Aug 27 2008, 10:55 AM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
My son and I have a real problem and we need some help. My son is a licensed blaster. He has been asked to stimulate oil wells with dynamite. I am trying to help him. In short, we will fabricate a "torpedo." Currently, we are thinking of using a 5' length of 1.5" PVC with the down end made into a point. The torpedo will be filled with 2 sticks of dynamite and filled with as dense a sand/gravel as we can find. It will be dropped down a 5" pipe filled with water. It is estimated that it is 640' to the bottom. Can you help me calculate how long it will take the torpedo to reach the bottom? (We need to make sure it gets to the bottom before the fuse ignites the dynamite!!) I am sure the efficiency through the water, drag, is an important and not known for sure variable, but perhaps there is a range that would get us close enough.
Any guidance or leads would be most appreciated. |
Travisfling |
Aug 28 2008, 03:07 PM
Newbie Group: Members Posts: 10 Joined: 25-August 08 From: Ohio Member No.: 9,459 Region Association: Upper MidWest |
This just seems like a crazy question... I think the only thing that you'll KNOW to be true is going to be pressure. it doesn't matter how large the diameter of the tube is, just the depth. I would find the pressure for -640 of water, and then get a detonator based on that. Then you wouldn't have to worry about how long it took, or whatnot, it would just blow when it got to that pressure.
Lo-Fi Version | Time is now: 3rd June 2024 - 01:55 AM |
