914/6 conversion oil line routing |
rfuerst911sc |
Aug 31 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
O.K. I'm making progress on my conversion and I'm ready to start installing the oil tank. I have the DW Design aluminum tank and I've cut out the inner fender to accommodate the tank but haven't mounted it yet. I have a few questions on the oil line routing. The forward oil line ( the one under the relay board ) I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? Has anyone ever used the hole for the engine tray drain lines? I know this is not as direct as a forward hole but it's already drilled and I'm not running a engine tray so the hole isn't being used. And the bottom line from the tank can I see some pics of the routing and possibly the installation of a " tee " for draining the tank? Actually any pics of either oil line would be a great help. I do plan on running a front oil cooler so I will be useing a firewall mounted thermostat, so any pics of that would help also. Thanks guys (IMG:style_emoticons/default/beerchug.gif)
Joe Bob |
Aug 31 2008, 01:14 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Nice pics Andy....I see you have an auto focus now... (IMG:style_emoticons/default/biggrin.gif)
BTW, don't go cheap on the thermostat. I used a MOCAL like in Andy's pic above....to replace the cheap ass one the DAPO used. It failed during start up and sent a big slug of cold oil and assembly lube to the oil cooler. BAM....the whole crankcase vented to the floor of my garage.....instant EXXON Valdez. One difference is that "I" route the lines on the driver side longs, thru the sender well and into the trunk. No biggy, just personal preference. Saves a bit on lines and bends.... |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:36 PM |
