914/6 conversion oil line routing |
rfuerst911sc |
Aug 31 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
O.K. I'm making progress on my conversion and I'm ready to start installing the oil tank. I have the DW Design aluminum tank and I've cut out the inner fender to accommodate the tank but haven't mounted it yet. I have a few questions on the oil line routing. The forward oil line ( the one under the relay board ) I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? Has anyone ever used the hole for the engine tray drain lines? I know this is not as direct as a forward hole but it's already drilled and I'm not running a engine tray so the hole isn't being used. And the bottom line from the tank can I see some pics of the routing and possibly the installation of a " tee " for draining the tank? Actually any pics of either oil line would be a great help. I do plan on running a front oil cooler so I will be useing a firewall mounted thermostat, so any pics of that would help also. Thanks guys (IMG:style_emoticons/default/beerchug.gif)
jt914-6 |
Sep 2 2008, 06:47 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Here is a pic of my "T" for draining the oil. Someone said that sometimes the oil valve fails. I've used them (the type in the pic) for years and have had no problem. There is no real oil pressure in that line, so that wouldn't be a problem. The only way I can see how it would fail is if it was hit from bottoming out the car.
If you didn't want to use a drain valve, just insert a double male connector and loosen one of the hoses. As far as getting the lines to a front cooler, I am running the "in" line through the passenger side longitudnal side and the "return" line in the driver's side. I used 12an stainless hose and slid the hoses through a oversize garden type hose for protection. In the past I ran the lines along the driver's side on the outside and around the left front fender and into the trunk that way. I just thought that it was exposing the lines too much (side impact & front tire blowing out and taking out lines) so I decided to run the lines in the old heat tubes to the front............Hope this helps............ Attached image(s) |
Lo-Fi Version | Time is now: 13th June 2024 - 03:45 AM |
