914/6 conversion oil line routing |
rfuerst911sc |
Aug 31 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
O.K. I'm making progress on my conversion and I'm ready to start installing the oil tank. I have the DW Design aluminum tank and I've cut out the inner fender to accommodate the tank but haven't mounted it yet. I have a few questions on the oil line routing. The forward oil line ( the one under the relay board ) I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? Has anyone ever used the hole for the engine tray drain lines? I know this is not as direct as a forward hole but it's already drilled and I'm not running a engine tray so the hole isn't being used. And the bottom line from the tank can I see some pics of the routing and possibly the installation of a " tee " for draining the tank? Actually any pics of either oil line would be a great help. I do plan on running a front oil cooler so I will be useing a firewall mounted thermostat, so any pics of that would help also. Thanks guys (IMG:style_emoticons/default/beerchug.gif)
jt914-6 |
Sep 2 2008, 06:09 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
In the pic the engine oil cooler is attached to the solid steel line making the 90 degree bend going toward the engine. The pic was taken from the driver's side. You can hardly see the line from the bottom of the tank in the left side. It is a 3.0 engine using the original 914-6 engine oil cooler. I loosen the hose on either side of the drain valve and point it down to drain and then back in the position it is now when I'm done. It works quite well.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:59 PM |
