914/6 conversion oil line routing |
rfuerst911sc |
Aug 31 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
O.K. I'm making progress on my conversion and I'm ready to start installing the oil tank. I have the DW Design aluminum tank and I've cut out the inner fender to accommodate the tank but haven't mounted it yet. I have a few questions on the oil line routing. The forward oil line ( the one under the relay board ) I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? Has anyone ever used the hole for the engine tray drain lines? I know this is not as direct as a forward hole but it's already drilled and I'm not running a engine tray so the hole isn't being used. And the bottom line from the tank can I see some pics of the routing and possibly the installation of a " tee " for draining the tank? Actually any pics of either oil line would be a great help. I do plan on running a front oil cooler so I will be useing a firewall mounted thermostat, so any pics of that would help also. Thanks guys (IMG:style_emoticons/default/beerchug.gif)
jt914-6 |
Sep 2 2008, 06:30 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Here's a pic of what a friend did for the oil drain. It looks like what you want to do.
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:46 PM |
