> Painting inside the longs, access through the hell hole
ahdoman
post Sep 2 2008, 10:16 PM
It's phonetic...Ah-D-O-Man (Audioman)
I did an extensive search to no avail...I thought I remember someone mentioning a way to be able to spray paint (POR 15 or other rust treatment) inside the longs just by making a small access hole? I need to close up my hell hole repair but before I do I would like to spray rust treatment into the long. Thankfully the long is not rusted but I can see surface rust down in there. Anybody got any suggestions? A list of parts to do that would be great!
Joe Owensby
post Sep 3 2008, 06:06 PM
JoeO
Eastwood sells just what you need. They have a kit that includes the waxy type sealant along with an assortment of wands needed to spray inside cavities. I used their stuff on mine. You can get one of the spray nozzles put on the end of a 3/8 inch flexible hose, and work it up through the oval hole mentioned earlier. They have spray nozzles that spray out the end, and also out the side. using both of these allows you to get up into the long and also the sides , even with the air tube still in the long. Just spray and rotate to get full coverage as you pull out the hose. I also accessed the front portion of the inner long through a hole inside the front door jam. JoeO
ahdoman   Painting inside the longs   Sep 2 2008, 10:16 PM
Rusty   There is an oval access hole from inside the passe...   Sep 2 2008, 10:21 PM
2-OH!   Make a swab using a long piece of wire and a wad o...   Sep 2 2008, 10:42 PM
craig downs   The thread is somewhere I saw it a couple of month...   Sep 3 2008, 03:41 AM
ahdoman   Thanks Craig. That's what I'm looking for....   Sep 3 2008, 09:00 AM
r_towle   go to Eastwood, they have all the cool wands. Ric...   Sep 3 2008, 01:01 PM
SirAndy   (POR 15 or other rust treatment) POR 15 is *not...   Sep 3 2008, 01:18 PM
SirAndy   more on that here: http://www.914world.com/bbs2/i...   Sep 3 2008, 01:22 PM
SirAndy   Looks like "Dinol cavity wax" is what th...   Sep 3 2008, 01:24 PM
r_towle   Eric, partsman, had ziebart rust proofing on his c...   Sep 3 2008, 01:43 PM
Rusty   Years ago, some jackass wrote a Pelican article th...   Sep 3 2008, 02:13 PM
sww914   Modern VW's are built with so much wax in the ...   Sep 3 2008, 04:10 PM
Joe Owensby   Eastwood sells just what you need. They have a kit...   Sep 3 2008, 06:06 PM
Wes V   Steve; I've seen the spray "wands" ...   Sep 3 2008, 07:11 PM
ahdoman   WOW! Thanks for all the good replies everybody...   Sep 3 2008, 11:20 PM
shoguneagle   Hi, I may be the one your are referring to painti...   Sep 3 2008, 11:30 PM
ahdoman   Hey Steve - good info but what I am looking for is...   Sep 3 2008, 11:42 PM
9146986   My post from '05 OK, my secret technique reve...   Sep 4 2008, 07:31 AM
Bartlett 914   My post from '05 OK, my secret technique rev...   Sep 4 2008, 10:25 AM
dflesburg   It was hot as hell here yesterday, my daughters ca...   Sep 4 2008, 10:44 AM
charliew   All of the above is good info. Remember the ospho ...   Sep 4 2008, 10:49 AM
southernmost914   This is the stuff! I have used this for over 1...   Sep 5 2008, 02:13 PM
shoguneagle   Hey, Perry--- I did watch all your historic threa...   Sep 5 2008, 09:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:19 PM
