| Lavanaut |
Jun 11 2008, 12:52 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
After a good amount of info from all sorts of people in response to this thread, I went back and skimmed what I could wrap my head around. Here's what I've come up with (slowly adding links to pics as I have time):
Items in green are the most-recently added. Items in red have been recently updated/changed due to new information. Cowl-to-Fender Seam: absent (metal-filled) or empty for very early 70 (up to #49), rubber seam thereafter. (IMG:style_emoticons/default/confused24.gif) Ignition Switch: on dash, left of column for 70 & 71, on right side of column for 72 Interior Mirror: small version for 70 and 71, larger for 72 Dash Top: wide opening for glovebox for 70 & 71, narrower for 72 (to accommodate dash vents) Dash Vents: Absent for 70 & 71, present for 72 Door Panels: smooth vinyl for 70 & 71, basketweave for 72 Glove Box: wide for 70 & 71, narrow for 72 (to accommodate dash vents) Main Wiring Harness: hybrid /4-/6 harness for 72 cars Passenger Foot Rest ("dogbone"): present in 70 & 71, replaced with foam pad on bulkhead for 72 cars Passenger Seat: fixed for 70 & 71, moveable for 72 Rear Bumper: squared off for 70 and early 71, rounded for later 71 and 72 Seat Inserts: smooth vinyl for 71, basketweave for 70 & 72 Seatbelts: non-retractable for all years Steering Column: /4 steering column for 72 cars If you know of further differences, please post to this thread and I'll include them in this list. Please include a picture if you can and I'll link to it from here. And thanks to everyone who's contributed! (IMG:style_emoticons/default/beerchug.gif) Reid This post has been edited by Lavanaut: Oct 15 2008, 07:07 PM |
| GeorgeRud |
Jun 11 2008, 02:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Early cars had a finished cowl to fender seam, no black rubber filler strip.
| SirAndy |
Jun 11 2008, 03:03 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Early cars had a finished cowl to fender seam, no black rubber filler strip. i don't think that's true for any of the production cars. i have seen that on some of the prototypes, but never on a production car ... (IMG:style_emoticons/default/idea.gif) Andy |
| davep |
Jun 11 2008, 03:57 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Early cars had a finished cowl to fender seam, no black rubber filler strip. i don't think that's true for any of the production cars. i have seen that on some of the prototypes, but never on a production car ... George is correct. Quoting from the factory bulletin: effective from 4702900444 and 9140430052 fender beadings are inserted between the fender and cowl So this is not a difference between 914/4 and 914/6, only an early vs late instance. |
| burton73 |
Jun 12 2008, 12:53 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Early cars had a finished cowl to fender seam, no black rubber filler strip. i don't think that's true for any of the production cars. i have seen that on some of the prototypes, but never on a production car ... George is correct. Quoting from the factory bulletin: effective from 4702900444 and 9140430052 fender beadings are inserted between the fender and cowl So this is not a difference between 914/4 and 914/6, only an early vs late instance. It is very clear that my car 9140430041 has fender beading. So what is up with that? Bob Burton ![]() ![]() |
| gms |
Sep 1 2008, 04:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
Early cars had a finished cowl to fender seam, no black rubber filler strip. i don't think that's true for any of the production cars. i have seen that on some of the prototypes, but never on a production car ... George is correct. Quoting from the factory bulletin: effective from 4702900444 and 9140430052 fender beadings are inserted between the fender and cowl So this is not a difference between 914/4 and 914/6, only an early vs late instance. It is very clear that my car 9140430041 has fender beading. So what is up with that? Bob Burton ![]() ![]() The important difference is that the cowl and fenders were changed after 4702900444/9140430052 my car (914.043.0012) had the black bead in it but this was most likely done by the PO, 914.043.0011 is leaded. I have attached 2 photo the red one is 914.043.0012. note the contour of the fender edge and the width between the a-pillar and the seam. Attached image(s)
| Lavanaut |
Sep 3 2008, 07:00 PM
I have attached 2 photo the red one is 914.043.0012. Is that bahia red? Original color? I came up with a few more: 1. Dash vents were introduced in 72 which meant: 2. The glove box got narrower 3. The dash top had a narrower opening for the (now narrower) glove box Also the rear view mirror (interior) is tiny in the 70 cars and may have been used in early 71 cars but I haven't been able to confirm that... (IMG:style_emoticons/default/idea.gif) Reid |
| smontanaro |
Sep 3 2008, 09:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
| Lavanaut |
Sep 3 2008, 11:23 PM
Got dimensions for "tiny" and not tiny? Maybe a side-by-side pic? Actually yeah, I can do dimensions and a side-by-side here in the next couple weeks. I'll post back here when I can. What I'd like to do for this thread is do a side-by-side (or at least picture-by-picture) example for all of the differences discussed. (IMG:style_emoticons/default/idea.gif) |
Lavanaut 914-6: Differences from year to year Jun 11 2008, 12:52 PM
Root_Werks I know a couple simple ones like, 69-70 no pass mo... Jun 11 2008, 12:55 PM
6freak
I know a couple simple ones like, 69-70 no pass m... Jun 11 2008, 01:36 PM
Phoenix 914-6GT
I know a couple simple ones like, 69-70 no pass ... Jun 11 2008, 01:38 PM
ericread Did you check Jeff Bowlsby's site? It seems t... Jun 11 2008, 12:59 PM
Phoenix 914-6GT 70-71 has the 911 style ignition switch. 72 has an... Jun 11 2008, 12:59 PM
6freak
Early cars had a finished cowl to fender seam, no... Jun 11 2008, 02:19 PM
George is correct. Quoting from the factory bulle... Jun 11 2008, 05:44 PM
It is very clear that my car 9140430041 has fende... Jun 12 2008, 01:09 PM
gms here is #41 marked up Sep 1 2008, 04:44 PM
gms Here is 914.043.0035 it had a filled seam Sep 1 2008, 04:46 PM
gms
I have attached 2 photo the red one is 914.043.0... Sep 3 2008, 10:57 PM
Jeffs9146
Early meaning 69? :confused: Jun 11 2008, 02:15 PM
McMark The seam is the line on either side, running from ... Jun 11 2008, 02:28 PM
6freak
The seam is the line on either side, running from... Jun 11 2008, 02:32 PM
Lavanaut This is great info guys ~ keep it coming and I wil... Jun 11 2008, 02:35 PM
Jeffs9146 I have never seen one that was not done by the own... Jun 11 2008, 02:36 PM
markb There's some misinformation here. Check your f... Jun 11 2008, 02:44 PM
ericread Sorry, in my earlier post I failed to include the ... Jun 11 2008, 02:45 PM
6freak
Sorry, in my earlier post I failed to include the... Jun 11 2008, 03:02 PM
ericread
[quote name='ericread' post='1043794' date='Jun 1... Jun 11 2008, 03:14 PM
Jeffs9146
That's what I thought but only from my exper... Jun 11 2008, 02:47 PM
Lavanaut
There's some misinformation here. Check your ... Jun 11 2008, 03:00 PM
Does a thread like this already exist? I did che... Jun 11 2008, 03:01 PM
Lavanaut
apparently, you didn't look very hard ... :r... Jun 11 2008, 03:23 PM
That's a /4 vs. /6 list....is it not?
it sur... Jun 11 2008, 03:30 PM
Lavanaut
it sure is, it's got info on all the things d... Jun 11 2008, 03:38 PM
It seems you disagree...
nope ... just trying to... Jun 11 2008, 03:51 PM
Lavanaut
It seems you like to lean back and let others do ... Jun 11 2008, 04:05 PM
Did I manage to piss you off somehow?
jeeze, step... Jun 11 2008, 05:47 PM
Lavanaut Thanks Dave. For the record, when talking about S... Jun 11 2008, 04:09 PM
Lavanaut Fair enough.
My intention was (is) to extract t... Jun 11 2008, 05:56 PM
Heeltoe914
There's some misinformation here. Check your ... Jun 11 2008, 06:21 PM
as I seem to understand it 72 914 6s are no more ... Jun 11 2008, 06:45 PM
Pat Garvey
Does a thread like this already exist? I did che... Jun 11 2008, 08:38 PM
Phoenix 914-6GT
Does a thread like this already exist? I did ch... Jun 11 2008, 09:46 PM
Lavanaut
You should have posted your questions there, not ... Jun 11 2008, 10:14 PM
lagunero
Anyone else out there wanna break my balls for s... Jun 12 2008, 01:17 AM
6freak
Anyone else out there wanna break my balls for ... Jun 12 2008, 10:27 AM
Gustl
[...] put togather with whatever Porsche had on t... Jun 12 2008, 11:38 AM
ericread Boy, I was in a really shitty mood today. Bad hea... Jun 11 2008, 10:07 PM
carr914 Jeez, you old timers need to lighten up. Reid aske... Jun 11 2008, 10:13 PM
Lavanaut So if I'm not mistaken, the interior of the ... Jun 11 2008, 10:20 PM
Gustl
So if I'm not mistaken, the interior of the ... Jun 11 2008, 11:37 PM
smontanaro only the MY'71 cars had the very-similar-to-re... Jun 12 2008, 12:14 PM
Gustl
So you're saying that the basket weave door p... Jun 12 2008, 12:27 PM
Gustl
So you're saying that the basket weave door p... Jun 12 2008, 12:35 PM
mel reckling
So if I'm not mistaken, the interior of the ... Jun 12 2008, 01:23 PM
Phoenix 914-6GT :chair: I'll bust your balls :evilgrin:
We... Jun 11 2008, 10:22 PM
Lavanaut
You going to come up to the WCR?
Oh how I wish I... Jun 11 2008, 10:37 PM
Lavanaut Ahhhh...nice Gustl, thanks. This should probably ... Jun 11 2008, 11:44 PM
Eric_Shea MY08 - 3.6 engines Jun 12 2008, 12:30 PM
Eric_Shea My MY70 - smooth finish on the door panels.
Pic... Jun 12 2008, 12:34 PM
Lavanaut
Pick me! Pick me! Pick me! You... Jun 12 2008, 12:45 PM
Gustl
Thought I'd read elsewhere that they were bas... Jun 12 2008, 01:46 PM
Gustl
MY'70 - smooth surface
MY'71 - smooth sur... Jun 13 2008, 08:36 AM
6freak
[quote name='Lavanaut' post='1044168' date='Jun 1... Jun 13 2008, 08:47 AM
Lavanaut MY'70 seat inlays (only in colour of trim)
- ... Jun 13 2008, 03:43 PM
Gustl
So which year would these be? I believe them to ... Jun 13 2008, 05:29 PM
Lavanaut this looks like the MY'71 "leatherette pe... Jun 13 2008, 05:51 PM
Gustl
Ok, making sense to me now Gustl, you're a pa... Jun 14 2008, 05:57 AM
Eric_Shea
#11 is w/o the seam. Jun 12 2008, 06:01 PM
got a picture of that?
... Jun 13 2008, 12:15 PM
Eric_Shea Yes Sir but for some reason he doesn't want th... Jun 13 2008, 03:33 PM
GeorgeRud I seemed to start quite a discussion when I mentio... Jun 13 2008, 05:46 PM
Dave_Darling Rats, I wish I could remember a source. I thought... Jun 14 2008, 12:17 AM
Thus not helping the confusion in any way whatsoe... Jun 14 2008, 12:33 AM
Eric_Shea
Agree... just spent a lot of time with the mop a... Jun 14 2008, 02:11 PM
Phoenix 914-6GT Good think I don't believe in carma or Karma :... Jun 14 2008, 02:27 PM
Gustl
How about the 916s. They are sixes too right :D
... Jun 14 2008, 02:51 PM
Phoenix 914-6GT Thanks Wolfgang
Any info on the Engines that came... Jun 14 2008, 02:59 PM
Lavanaut [woof]
Nicely done Eric, thanks. :thumbsup:
Jon,... Jun 14 2008, 03:56 PM
Phoenix 914-6GT
[woof]
Jon... Jun 14 2008, 04:24 PM
Gustl
One thing I've always been curious about was ... Jun 14 2008, 04:40 PM
carr914 My carrma ran oer your dogma :D
T.C. Jun 14 2008, 04:24 PM
Phoenix 914-6GT I really want one of those 914-6-VW-PORSCHE badges... Jun 14 2008, 04:55 PM
carr914 Auto Atlanta has them in stock I think Jun 14 2008, 04:57 PM
Phoenix 914-6GT
Really? :... Jun 14 2008, 05:24 PM
carr914 Jon, Page 118 of their catalog. Item G914 559 112 ... Jun 14 2008, 06:38 PM
Phoenix 914-6GT Sounds good to me T.C. Let me know. Jun 15 2008, 12:01 AM
Lavanaut Thanks to Rusty for moving this topic to the origi... Sep 9 2008, 06:44 PM
sixerdon
After a good amount of info from all sorts of pe... Sep 13 2008, 08:42 PM
Lavanaut
Reid,
I totally missed your ensemble of differenc... Sep 18 2008, 11:42 AM
Lavanaut Mel has confirmed that the seatbelts in his '7... Oct 15 2008, 07:04 PM
mel reckling Here's a shot, sorry it came out so bad.
:dr... Oct 15 2008, 07:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:01 AM |
