| iamchappy |
Sep 10 2008, 02:30 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I have to replace the starter ring on my sons 924S ( ring was trashed due to wrong starter (IMG:style_emoticons/default/ar15.gif) i was sold) I am almost there, but am unable to pull the torque tube out of the front bellhousing. i have been at it for two days now and am considering making it a parts car if i cant pull the damn thing out. it is suppose to come out without force. I have all the workshop manuals and advice on other forums but need some sort of trick to make it come out.
(IMG:style_emoticons/default/smash.gif) |
| r_towle |
Sep 10 2008, 06:59 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Dont forget to remove the front bumper, radiator, motor and heater core so you can properly access the little C clip...
Might need to remove the center console, shifter , radio, dash board and steering wheel also.. Seriously. While all you 924S experts are paying attention. How do you replace the heater hoses that go to the heater core? It appears that the clamp is inside the car??? Is that right? Do I need to remove the heater core to get to these hose clamps? Its getting cold and my looped back hose needs to be replaced... Rich |
| scotty b |
Sep 10 2008, 07:07 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Dont forget to remove the front bumper, radiator, motor and heater core so you can properly access the little C clip... Might need to remove the center console, shifter , radio, dash board and steering wheel also.. Seriously. While all you 924S experts are paying attention. How do you replace the heater hoses that go to the heater core? It appears that the clamp is inside the car??? Is that right? Do I need to remove the heater core to get to these hose clamps? Its getting cold and my looped back hose needs to be replaced... Rich IIRC the glove box needs to be dropped, not a big deal. Then again I haven't f-ed with a 924/early 944 in several years now (IMG:style_emoticons/default/rolleyes.gif) |
iamchappy OT- 924s Torque Tube removal Sep 10 2008, 02:30 PM
ClayPerrine From experience....
the pilot bearing fails, then... Sep 10 2008, 03:07 PM
jcd914 I assume you have the trans out, shift lever unbol... Sep 10 2008, 03:13 PM
iamchappy First off it is and Auto, second everything is rem... Sep 10 2008, 03:32 PM
iamchappy I can see that the rubber dampner thingie on the f... Sep 10 2008, 03:44 PM
iamchappy I think i've got it! the bolts that i thou... Sep 10 2008, 04:05 PM
jcd914
I think i've got it! the bolts that i tho... Sep 10 2008, 06:36 PM
scotty b Did you remove the allen socket pinch bolt from th... Sep 10 2008, 06:49 PM
scotty b I've got a real nice manual setup I could sell... Sep 10 2008, 06:58 PM
jcd914
Dont forget to remove the front bumper, radiator,... Sep 10 2008, 07:17 PM
iamchappy All is out and ready to go back in. Without a doub... Sep 10 2008, 08:09 PM
jasons Welcome to 924/944 ownership! You don't r... Sep 10 2008, 09:22 PM
jcd914 When I was making my living off them I learned to ... Sep 11 2008, 02:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 11:51 AM |
