V8 guys - Overheating Fuel Pump in the Front Trunk.., Where do you mount it? |
cobra94563 |
Sep 15 2008, 10:02 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I have an overheating fuel pump in the front trunk. I think it overheats because of the heat coming off the radiator and screws up the pump enough to so I loose fuel pressure down to 1psi.
The pump is a new holley red w/a holley regulator. The pump gets so hot you cannot keep you hand on it. I iced it down a bit and my pressure immediately comes back up. I considered the heat could be from the pump, but the wiper motors also get too hot to touch. So where do you mount your pump (if not in the front trunk)? Or what kind of pump do you have (if in the front trunk)? ..or maybe I have to cut more openings..? (IMG:style_emoticons/default/idea.gif) |
messix |
Sep 15 2008, 11:06 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
it will run cooler if you run it as a return system.
cobra94563 |
Sep 15 2008, 11:13 AM
Wanna9146 |
Sep 15 2008, 11:18 AM
Member Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States |
messix |
Sep 15 2008, 11:29 AM
it will run cooler if you run it as a return system. Sorry, what does that mean? As original. One hose fuel-pump to motor. Return line fuel-pump to tank. it takes a bypass regulator, fuel to the pump to the reg. then reg pressure to carb/fuel rail, then bypass port to return line to tank. |
Lo-Fi Version | Time is now: 16th June 2024 - 08:47 AM |
