Please help! Another winking/oscilating headlight question, Switch on and sometimes they will start "the dance". |
BRAVE_HELIOS |
Sep 18 2008, 10:52 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/WTF.gif) So sometimes when I switch the headlights on , they will begin to oscilate, wink, blink... as one comes up the other goes down and they will continue to do this until I switch them off (they both go to the off/down position). Then if I switch them on again, they will operate normally. I've swapped relays by the headlights; but made no difference.
Any ideas or thoughts? (IMG:style_emoticons/default/type.gif) |
smooth_eddy |
Sep 19 2008, 01:18 AM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
Check the relay's first. I had the same problem. I just cleaned the relay's and sockets with contact cleaner and they were fine after that. If that does not work, try chasing bad grounds.
Good luck. Eddy |
Lo-Fi Version | Time is now: 8th June 2024 - 10:14 PM |
