Grounding Stud, plastic washer?? |
rmital |
Sep 23 2008, 12:09 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
decided to finially dig in and clean up some ground connections last night. Started with the stud that connects to the (-) from the battery. There seems to be a "plastic" washer behind the nut/washer/wire. It also seems to be fixed. Is this original?
I would have figured the wire would have grounded directly to the body not just to the stud connected to the body. any thoughts...pictures...etc.... I'll take a pic of mine tonight |
davep |
Sep 23 2008, 12:18 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Not original AFAIK.
It is sometimes a good idea to add a cable from the stud on the engine wall to the fan shroud. This would make a more direct path than through the body, to the transmission ground strap, through the transmission, and through the engine case. The alternator is grounded through the fan shroud, and the starter through the transmission case. Even solid appearing bodies are not the best conductors. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:33 AM |
